[Qgis-user] How to generate (vector)contour lines for point data?
Paolo Cavallini cavallini at faunalia.it
Mon Oct 1 07:27:09 PDT 2012
Il 01/10/2012 15:16, Micha Silver ha scritto:
> You will need two steps. First use the points to create a raster surface. In the
> Raster menu, choose Analysis->Grid. With this GDAL tool you can create a raster using
> some simple algorithms. THen using this new raster as your surface, use the GDAL tool
> Raster->Extraction->Contour to get vector contour lines.
There is also a plugin that does the same, without the intermediate raster.
All the best.
Paolo Cavallini - Faunalia
www.faunalia.eu
Full contact details at www.faunalia.eu/pc
Nuovi corsi QGIS e PostGIS: http://www.faunalia.it/calendario
