[Qgis-user] Label Rotation
Piotr Pachół piotrpachol at gmail.com
Fri Oct 5 13:58:39 PDT 2012
Hello,
I am facing with the same problem.
All labels with angle from 90 to 269 degrees are drawn in improper way.
Additionaly there are other problems during labelling:
1. it is necessary to to indicate coordinates x and y when you want to
rotate label. It shouldn't be necessary for point objects - then insert
point of label is as default insert point of object.
2. When using rotating labels icon  - location of mouse indicator is not
always situated on line of rotation arrow. It is therefore difficult to
insert a label which should be for instance parallel to another object.
Regards,
Piotr
W dniu 2012-10-04 17:54, Bernhard Ströbl pisze:
> Dear list,
> I am trying to get lables facing upside down with no avail. QGIS
> always turns them around. So the label is drawn identically when
> entering 0 or 180 degrees.
> Is there any setting that forces QGIS to act like that? If this is the
> default behaviour I would conider it a bug and report it.
> I am using QGIS master with the new labelling engine.
> regards
> Bernhard
