[Qgis-user] Problem installing Profile plugin
Guido Paliaga gpaliaga at gmail.com
Wed Oct 10 13:44:47 PDT 2012
Thanks so much!
Guido
2012/10/9 Etienne Tourigny <etourigny.dev at gmail.com>
> On Tue, Oct 9, 2012 at 1:07 AM, Andre Joost <andre+joost at nurfuerspam.de>
> wrote:
> > Am 09.10.2012 02:23, schrieb William Kyngesburye:
> >> Profile tool is a plugin affected by an incompatibility of PyQwt5
> >> with recent PyQt versions.  It needs to be fixed to use another
> >> graphing toolbox like Matplotlib.  Until then it will be broken in
> >> the current QGIS.
> Profile tool DOES support matplotlib - although perhaps it fails when
> pyqwt is not found.  See attached screenshot, using matplotlib for the
> plot.
> I'll try to fix this by the end of the weekend.
> > It also does not work on Qgis Master under Windows, but still works with
> > 1.8.0 there.
> > The author has promised me to rewrite the tool.
> activity is very low, original author does not have any time to
> dedicate on this.  I am working on some UI and functionality
> improvements,  but I don't have he time to rewrite the tool.
> > Greetings,
> > André Joost
> > Qgis-user mailing list
> > Qgis-user at lists.osgeo.org
> > http://lists.osgeo.org/mailman/listinfo/qgis-user
Dott. Geol. Guido Paliaga, PhD
Mobile +39 335 6901747
Skypeid: gpaliaga
<gpaliaga at gmail.com>gpaliaga at gmail.com
<paliaga at geologiliguria.it>paliaga at geologiliguria.it
Posta certificata: gpaliaga at epap.sicurezzapostale.it
www.edizioniilpiviere.com
www.guidopaliaga.com
Think before you print: Rispetta l'ambiente: se non ti è necessario, non
stampare questa mail.
Le informazioni contenute nella presente comunicazione e i relativi
allegati possono essere riservate e sono, comunque, destinate
esclusivamente alle persone o alla Società sopraindicati. La diffusione,
distribuzione e/o copiatura del documento trasmesso da parte di qualsiasi
soggetto diverso dal destinatario è proibita, sia ai sensi dell’art. 616
c.p. , che ai sensi del D.Lgs. n. 196/2003. Se avete ricevuto questo
messaggio per errore, vi preghiamo di distruggerlo e di informarci
immediatamente  inviando un messaggio all’indirizzo e-mail
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20121010/8e765138/attachment.html>
