[Qgis-user] How to change the data source?
Etienne Tourigny
etourigny.dev at gmail.com
Tue Oct 16 06:44:57 PDT 2012
Why do you need to change the datasource, instead of simply opening a
new layer? Are there things like symbology that must be preserved?
If it's for creating maps, you can use the Print Composer, and simply
change layers.
If you need the same symbology, in the dev version (qgis-1.9) you can
setup symbology defaults for new layers, in the project properties.
Etienne
On Mon, Oct 15, 2012 at 4:20 PM, boesiii <boesiii at yahoo.com> wrote:
> I would like to be able to edit the location of the data source from within
> Qgis similar to the image attached.
> <http://osgeo-org.1560.n6.nabble.com/file/n5008819/source_button.png>
> View this message in context: http://osgeo-org.1560.n6.nabble.com/How-to-change-the-data-source-tp5008756p5008819.html
> Sent from the Quantum GIS - User mailing list archive at Nabble.com.
> Qgis-user mailing list
