[Qgis-user] QGIS-Webclient Layer-visibility
G. Allegri
giohappy at gmail.com
Fri Oct 19 00:40:51 PDT 2012
Great news Andreas!
GetProjectSettings is what we all were waiting to see ;)
Thx,
giovanni
2012/10/19 Andreas Neumann <a.neumann at carto.net>
> Hi Dieter,
> Just recently - the last couple days - Marco Hugentobler was working on
> several improvements regarding the WMS server.
> You can now use a new command called "GetProjectSettings" which would give
> a non-standard XML tree, similar to GetCapabilities, but containing more
> project related settings, like visible layers, attribute data and widget
> types, etc.
> This is now available in the server, but the webclient would have to be
> changed to use this new command. Matthias Walker from Sourcepole is working
> on it. Expect it to be available in the next couple days, along with my new
> project switcher.
> In QGIS desktop it is now also possible to hide layers, layouts and
> attributes from WMS and WFS - but they would still appear in the desktop
> project. This is also a recent improvement, only available in QGIS master.
> So please allow a couple of days to have this all available also in the
> web client.
> Andreas
> On Fri, 19 Oct 2012 09:13:51 +0200, Dieter Becker wrote:
>> Dear QGIS-users,
>> I have got a questions concerning the layer-visibility of the
>> QGIS-Webclient:
>> In some older mails (11/2011) of this mailinglist I found following
>> information:
>> There is also a pending feature in QGIS server that should allow to
>> retrieve layer visibility from the GetCapabilities XML document,
>> thus
>> eliminating the need to manually set layer visibility.
>> Andreas
>> Does someone of you know if there is found a convienient way in the
>> meantime to automatically determine the visible layers of a
>> qgis-project so that there is no need to write down everey layer for
>> the rest-adress?
>> I know that for example the qgis-cloud-plugin for QGIS produces a
>> js-config file that has the information about visible layers and
>> start-/maxExtent.
>> But is there also way to use something like this if I want to host my
>> own webclient?
>> best wishes,
>> Dieter
> Andreas Neumann
> Böschacherstrasse 10A
> 8624 Grüt (Gossau ZH)
> Switzerland
> ______________________________**_________________
> Qgis-user mailing list
> http://lists.osgeo.org/**mailman/listinfo/qgis-user<http://lists.osgeo.org/mailman/listinfo/qgis-user>
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20121019/ead4a264/attachment.html>
