[Qgis-user] ubuntu 12.10 issues
Rudi von Staden rudivs at gmail.com
Wed Oct 24 03:20:04 PDT 2012
Hi Nicholas,
My guess would be that during the upgrade, some of your repositories were
turned off. qgis (1.74+1.75~20120320-1.1) is the version in the 12.10
ubuntu repository, but it looks like you previously installed qgis from the
master repository (1.9.0+git20121015+5afd739~precise-ubuntugis1).
If you still want to use the cutting-edge qgis version, check in your
software sources (Ubuntu Software Center > Edit > Software Sources; then
Other Software tab) for something with "http://qgis.org/debian-nightly" in
it. Check that it now reads "http://qgis.org/debian-nightly quantal", and
enable it. Then from the command line, run "sudo apt-get update && sudo
apt-get install qgis". If that still doesn't work, I'd remove qgis (sudo
apt-get remove qgis), and then try to reinstall it (sudo apt-get install
qgis).
If you'd rather revert to a more stable and tested version of qgis, the
instructions may be different...
Kind regards,
Rudi
On Wed, Oct 24, 2012 at 11:38 AM, Nicholas Efremov-Kendall <
n.e.kendall at gmail.com> wrote:
> Hi All,
> Still having issues with my ubuntu install. I just upgraded to 12.10, but
> I was having problems before. It looks like the system is expecting 1.7
> dependencies, but tries to install 1.9 and fails.
> The following packages have unmet dependencies:
>  qgis : Depends: qgis-providers (= 1.7.4+1.7.5~20120320-1.1) but
> 1.9.0+git20121014+2754df0~precise1 is to be installed
>         Depends: qgis-common (= 1.7.4+1.7.5~20120320-1.1) but
> 1.9.0+git20121015+5afd739~precise-ubuntugis1 is to be installed
>         Recommends: qgis-plugin-grass but it is not going to be installed
> E: Unable to correct problems, you have held broken packages.
> Any ideas?
> Qgis-user mailing list
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20121024/ef884d62/attachment.html>
