[Qgis-user] ubuntu 12.10 issues
Nicholas Efremov-Kendall n.e.kendall at gmail.com
Fri Oct 26 20:36:40 PDT 2012
Hi Rudi,
Yes, at this point I just want to go back to a stable version. i've changed
my repos in etc/apt/sources.list to
 deb http://extras.ubuntu.com/ubuntu precise main
 deb-src http://extras.ubuntu.com/ubuntu precise main
and I still get this as an error in terminal.
 qgis : Depends: qgis-providers (= 1.8.0-1~quantal1) but
1.9.0+git20121014+2754df0~precise1 is to be installed
        Depends: qgis-common (= 1.8.0-1~quantal1) but
1.9.0+git20121015+5afd739~precise-ubuntugis1 is to be installed
So, how do I roll back to 1.8? Also, my software sources gui is broken.
On Wed, Oct 24, 2012 at 12:20 AM, Rudi von Staden <rudivs at gmail.com> wrote:
> Hi Nicholas,
> My guess would be that during the upgrade, some of your repositories were
> turned off. qgis (1.74+1.75~20120320-1.1) is the version in the 12.10
> ubuntu repository, but it looks like you previously installed qgis from the
> master repository (1.9.0+git20121015+5afd739~precise-ubuntugis1).
> If you still want to use the cutting-edge qgis version, check in your
> software sources (Ubuntu Software Center > Edit > Software Sources; then
> Other Software tab) for something with "http://qgis.org/debian-nightly"
> in it. Check that it now reads "http://qgis.org/debian-nightly quantal",
> and enable it. Then from the command line, run "sudo apt-get update && sudo
> apt-get install qgis". If that still doesn't work, I'd remove qgis (sudo
> apt-get remove qgis), and then try to reinstall it (sudo apt-get install
> qgis).
> If you'd rather revert to a more stable and tested version of qgis, the
> instructions may be different...
> Kind regards,
> Rudi
> On Wed, Oct 24, 2012 at 11:38 AM, Nicholas Efremov-Kendall <
> n.e.kendall at gmail.com> wrote:
>> Hi All,
>> Still having issues with my ubuntu install. I just upgraded to 12.10, but
>> I was having problems before. It looks like the system is expecting 1.7
>> dependencies, but tries to install 1.9 and fails.
>> The following packages have unmet dependencies:
>>  qgis : Depends: qgis-providers (= 1.7.4+1.7.5~20120320-1.1) but
>>         Depends: qgis-common (= 1.7.4+1.7.5~20120320-1.1) but
>>         Recommends: qgis-plugin-grass but it is not going to be installed
>> E: Unable to correct problems, you have held broken packages.
>> Any ideas?
>> Qgis-user mailing list
>> http://lists.osgeo.org/mailman/listinfo/qgis-user
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20121026/dc923f20/attachment.html>
