[Qgis-user] ubuntu 12.10 issues
Rudi von Staden
rudivs at gmail.com
Sat Oct 27 00:14:09 PDT 2012
Hi Nicholas,
It sounds like your repositories are in a bit of a mixed-up state if you
upgraded to 12.10 (quantal) and your sources.list has repos from 12.04
(precise). Also if your sources gui is broken, you might need to get ubuntu
to a stable state before looking at qgis. The first step is to check what
repositories and ppa's you have enabled. Could you attach or paste your
full /etc/apt/sources.list file? Also the output of this command run from
the terminal:
cat /etc/apt/sources.list /etc/apt/sources.list.d/*.list | grep ppa
Kind regards,
Rudi
On Sat, Oct 27, 2012 at 5:36 AM, Nicholas Efremov-Kendall <
n.e.kendall at gmail.com> wrote:
> Hi Rudi,
> Yes, at this point I just want to go back to a stable version. i've
> changed my repos in etc/apt/sources.list to
> deb http://extras.ubuntu.com/ubuntu precise main
> deb-src http://extras.ubuntu.com/ubuntu precise main
> and I still get this as an error in terminal.
> qgis : Depends: qgis-providers (= 1.8.0-1~quantal1) but
> 1.9.0+git20121014+2754df0~precise1 is to be installed
> Depends: qgis-common (= 1.8.0-1~quantal1) but
> 1.9.0+git20121015+5afd739~precise-ubuntugis1 is to be installed
> So, how do I roll back to 1.8? Also, my software sources gui is broken.
> On Wed, Oct 24, 2012 at 12:20 AM, Rudi von Staden <rudivs at gmail.com>wrote:
>> Hi Nicholas,
>> My guess would be that during the upgrade, some of your repositories were
>> turned off. qgis (1.74+1.75~20120320-1.1) is the version in the 12.10
>> ubuntu repository, but it looks like you previously installed qgis from the
>> master repository (1.9.0+git20121015+5afd739~precise-ubuntugis1).
>> If you still want to use the cutting-edge qgis version, check in your
>> software sources (Ubuntu Software Center > Edit > Software Sources; then
>> Other Software tab) for something with "http://qgis.org/debian-nightly"
>> in it. Check that it now reads "http://qgis.org/debian-nightly quantal",
>> and enable it. Then from the command line, run "sudo apt-get update && sudo
>> apt-get install qgis". If that still doesn't work, I'd remove qgis (sudo
>> apt-get remove qgis), and then try to reinstall it (sudo apt-get install
>> qgis).
>> If you'd rather revert to a more stable and tested version of qgis, the
>> instructions may be different...
>> Kind regards,
>> Rudi
>> On Wed, Oct 24, 2012 at 11:38 AM, Nicholas Efremov-Kendall <
>>> Hi All,
>>> Still having issues with my ubuntu install. I just upgraded to 12.10,
>>> but I was having problems before. It looks like the system is expecting 1.7
>>> dependencies, but tries to install 1.9 and fails.
>>> The following packages have unmet dependencies:
>>> qgis : Depends: qgis-providers (= 1.7.4+1.7.5~20120320-1.1) but
>>> Depends: qgis-common (= 1.7.4+1.7.5~20120320-1.1) but
>>> Recommends: qgis-plugin-grass but it is not going to be installed
>>> E: Unable to correct problems, you have held broken packages.
>>> Any ideas?
>>> Qgis-user mailing list
>>> Qgis-user at lists.osgeo.org
>>> http://lists.osgeo.org/mailman/listinfo/qgis-user
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20121027/1d3f0b8f/attachment.html>
