[Qgis-user] qgis , html & css
Andrea Peri aperi2007 at gmail.com
Wed Oct 24 12:22:58 PDT 2012
>Hi Andrea,
> In what context are you executing this javascript? QGIS Desktop, QGIS
> Webclient?
> In what component?
> I haven't heard that QGIS Desktop can run Javascript. The only part
> where it could potentially run javascript is Webkit, which is used in
> print composer and tooltips.
> So please better explain what you are doing.
Hi, sorry ,
I'm explain better.
I need to localize the clicked point on a map returned on the
text/html response from the wms server, when the user do an identify.
To do this I'm using a little javascript code.
a sample of the response I'm coding is this:
http://web.regione.toscana.it/wmsraster/com.rt.wms.RTmap/wms?map=wmscatasto&map_resolution=96&language=ita&&SERVICE=WMS&VERSION=1.3.0&REQUEST=GetFeatureInfo&BBOX=1620630.0,4855425.0,1620875.0,4855595.0&WIDTH=1000&HEIGHT=680&CRS=EPSG:3003&LAYERS=rt_cat.idcatpart.rt&STYLES=&FORMAT=image/png&QUERY_LAYERS=rt_cat.idcatpart.rt&INFO_FORMAT=text/html&I=500&J=340&FEATURE_COUNT=10
In the html I have installed a couple of "alert" to test the working of
javascript.
And if you see the map it has a little circle black on a specific position.
That circle is put here from a little javascript code.
All this work well on web browser.
I f I try to identify with qgis this layer from its wms.
I see the two alert , so the JS is working, but the map don't has the
circle
So there is something that don't work on javascript engine of qgis (the
webkit ?).
Andrea Peri
qwerty àèìòù
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20121024/cdf3f1cb/attachment.html>
