[Qgis-user] qgis , html & css
Andreas Neumann
a.neumann at carto.net
Wed Oct 24 13:18:50 PDT 2012
Hi Andrea,
So this has nothing directly to do with QGIS server or QGIS webclient,
as you just seem to use a WMS GetMap request and put it in some web page.
However, you may want to experiment with the SELECTION extension of QGIS
server, which allows you to highlight a certain feature:
see
http://hub.qgis.org/projects/quantum-gis/wiki/QGIS_Server_Tutorial#SELECTION-parameter
for an example.
In your case you could highlight an address or parcel using the
SELECTION parameter.
The Webgis of Kanton Glarus handles this.
Alternatively you could use OpenLayers to display the WMS map and
highlight the geometry with a WKT geometry. This is what we do in the
city of Uster.
Hope this helps?
Andreas
Am 24.10.2012 21:22, schrieb Andrea Peri:
>> Hi Andrea,
>> In what context are you executing this javascript? QGIS Desktop, QGIS
>> Webclient?
>> In what component?
>> I haven't heard that QGIS Desktop can run Javascript. The only part
>> where it could potentially run javascript is Webkit, which is used in
>> print composer and tooltips.
>> So please better explain what you are doing.
> Hi, sorry ,
> I'm explain better.
> I need to localize the clicked point on a map returned on the
> text/html response from the wms server, when the user do an identify.
> To do this I'm using a little javascript code.
> a sample of the response I'm coding is this:
> http://web.regione.toscana.it/wmsraster/com.rt.wms.RTmap/wms?map=wmscatasto&map_resolution=96&language=ita&&SERVICE=WMS&VERSION=1.3.0&REQUEST=GetFeatureInfo&BBOX=1620630.0,4855425.0,1620875.0,4855595.0&WIDTH=1000&HEIGHT=680&CRS=EPSG:3003&LAYERS=rt_cat.idcatpart.rt&STYLES=&FORMAT=image/png&QUERY_LAYERS=rt_cat.idcatpart.rt&INFO_FORMAT=text/html&I=500&J=340&FEATURE_COUNT=10
> In the html I have installed a couple of "alert" to test the working of
> javascript.
> And if you see the map it has a little circle black on a specific position.
> That circle is put here from a little javascript code.
> All this work well on web browser.
> I f I try to identify with qgis this layer from its wms.
> I see the two alert , so the JS is working, but the map don't has the
> circle
> So there is something that don't work on javascript engine of qgis (the
> webkit ?).
> Qgis-user mailing list
