[Qgis-user] Error installing Qgis-dev using OSGEO4w
Andre Joost andre+joost at nurfuerspam.de
Thu Oct 25 11:46:50 PDT 2012
For a clean install, rename your existing C:\OSGeo4w folder, and make a
new install in a new folder, with only qgis-dev selected in advanced
installation.
HTH,
André Joost
Am 25.10.2012 17:14, schrieb Alexandre Neto:
> I have
> gdal15.dll, gdal18.dll and gdal19.dll in C:\OSGeo4W\bin.
> I don't find any repeated files regarding gdal anywhere in my system drive.
> On Thu, Oct 25, 2012 at 12:56 PM, Andreas Neumann<a.neumann at carto.net>wrote:
>> Hi,
>> are there perhaps two or more gdal dlls on your system? Can you check on
>> your complete C drive and see if there are more dlls around for gdal?
>> Sometimes this is the cause of such problems.
>> Andreas
>> On Thu, 25 Oct 2012 12:33:03 +0100, Alexandre Neto wrote:
>>> Trying to install qgis-dev (1.9.0-93 or 1.9.0-93) using Osgeo4w
>>> installer, in windows vista 32bit, gives me the attached error:
>>> Translating the best I can, it's something like:
>>>   "Not possible to find procedure entry point ...bla bla bla... in the
>>> gdal19.dll dynamic library."
>>> Alexandre Neto
>> Andreas Neumann
>> Böschacherstrasse 10A
>> 8624 Grüt (Gossau ZH)
>> Switzerland
>> ______________________________**_________________
>> Qgis-user mailing list
>> http://lists.osgeo.org/**mailman/listinfo/qgis-user<http://lists.osgeo.org/mailman/listinfo/qgis-user>
