[Qgis-user] Other symbols in .eps format
Andreas Neumann a.neumann at carto.net
Tue Oct 30 00:06:33 PDT 2012
QGIS needs one symbol per file - so you need to split them apart if
several symbols are in one file.
I would recommend to save in plain SVG or optimized SVG, not in Inkscape
SVG, as this results in smaller files.
Andreas
Am 30.10.2012 07:53, schrieb Johan Nilsson:
> Thanks. But where do I load them,and can I separate/group them from the
> other symbols? I just see one big field with a lot of symbols.
> 2012/10/30 Alex Mandel <tech_dev at wildintellect.com>
>> On 10/29/2012 11:42 PM, Johan Nilsson wrote:
>>> Hi.
>>> I have downloaded swedish cartografical symbols in .eps-format. I wonder
>> if
>>> QGIS 1.8 Lisboa are able to use then and how I do use them? Can't find
>>> anything under 'Layer Properies'-->'Style'
>>> /Cheers
>> You need to convert them to svg. Should be possible using inkscape.
>> Enjoy,
>> Alex
> Qgis-user mailing list
