[Qgis-user] Other symbols in .eps format
Johan Nilsson joni8135 at gmail.com
Tue Oct 30 00:43:33 PDT 2012
Yes Thanx, they are single point symbols. But I still don' know how I can
make them appear in QGIS. Will test when I come home, cos here we just have
ArcGIS and MapInfo.
/Cheers
Den tisdagen den 30:e oktober 2012 skrev Andreas Neumann<a.neumann at carto.net
> Hi,
> QGIS needs one symbol per file - so you need to split them apart if
> several symbols are in one file.
> I would recommend to save in plain SVG or optimized SVG, not in Inkscape
> SVG, as this results in smaller files.
> Andreas
> Am 30.10.2012 07:53, schrieb Johan Nilsson:
>> Thanks. But where do I load them,and can I separate/group them from the
>> other symbols? I just see one big field with a lot of symbols.
>> 2012/10/30 Alex Mandel <tech_dev at wildintellect.com>
>>> On 10/29/2012 11:42 PM, Johan Nilsson wrote:
>>>> Hi.
>>>> I have downloaded swedish cartografical symbols in .eps-format. I
wonder
>>> if
>>>> QGIS 1.8 Lisboa are able to use then and how I do use them? Can't find
>>>> anything under 'Layer Properies'-->'Style'
>>>> /Cheers
>>> You need to convert them to svg. Should be possible using inkscape.
>>> Enjoy,
>>> Alex
>> Qgis-user mailing list
>> http://lists.osgeo.org/mailman/listinfo/qgis-user
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20121030/c6f59b69/attachment.html>
