[Qgis-user] WG: vector export (pdf/ps/svg): most promising approach?
Peter Schürch p.schuerch at meierpartner.ch
Mon Sep 3 22:16:28 PDT 2012
Yes indeed. I identified a vector layer with buffered oldstyle labels to cause the crash (last comment on http://hub.qgis.org/issues/4821)
Oldstyle without buffer and Newstyle with buffer work both.
For my problem I prefere Oldstyle because it allows you to place labels at specific relative positions next to the symbol (above, beneath, left, right), which is useful if single objects are labeled multiple times with different information.
Peter
-----Ursprüngliche Nachricht-----
Von: qgis-user-bounces at lists.osgeo.org [mailto:qgis-user-bounces at lists.osgeo.org] Im Auftrag von skampus
Gesendet: Montag, 3. September 2012 16:02
An: qgis-user at lists.osgeo.org
Betreff: Re: [Qgis-user] vector export (pdf/ps/svg): most promising approach?
i don't know if it is correlated to this issue
View this message in context: http://osgeo-org.1560.n6.nabble.com/vector-export-pdf-ps-svg-most-promising-approach-tp4999432p4999470.html
Sent from the Quantum GIS - User mailing list archive at Nabble.com.
Qgis-user mailing list
Qgis-user at lists.osgeo.org
http://lists.osgeo.org/mailman/listinfo/qgis-user
