[Qgis-user] new labelling method and rotation
Andreas Neumann a.neumann at carto.net
Wed Sep 5 04:05:58 PDT 2012
 You have to set x, y and the rotation column. The rotation does not
 work without a separate column for the position.
 Andreas
 On Wed, 5 Sep 2012 11:57:34 +0200,  wrote:
> Hello,
> I'd like tu use the new labelling method. Meanwhile, the rotation
> drop-down list which allows to select the field containing angle
> stays
> disabled.
> Did someone experience the same problem ?
> Thanks
> Jonathan A
 Andreas Neumann
 Böschacherstrasse 10A
 8624 Grüt (Gossau ZH)
 Switzerland
