[Qgis-user] new labelling method and rotation
Bernd Vogelgesang bernd.vogelgesang at gmx.de
Wed Sep 5 05:57:47 PDT 2012
Hi Jonathan,
i experienced this behavior only, when there are no fields with real or
integer definition in your dataset (so only strings).
Verify that by creating a new number field with the field calculator and
populate it with the values from your designated angle field and check if
the option is available then.
>  Hello,
> I'd like tu use the new labelling method. Meanwhile, the rotation
> drop-down list which allows to select the > field containing angle stays
> disabled.
> Did someone experience the same problem ?
> Thanks
> Jonathan A
Bernd Vogelgesang * Siedlerstrasse 2 * 91083 Baiersdorf * +49-9133-825374
