[Qgis-user] QGIS 1.8 crashed again
Nathan Woodrow madmanwoo at gmail.com
Wed Sep 5 04:43:16 PDT 2012
Roy,
Did you happen to using the import delimited data plugin?  Was it
enabled when you opened the project?
- Nathan
On Wed, Sep 5, 2012 at 9:35 PM, Roy Marsh <roymarsh11 at gmail.com> wrote:
> Rebooting does not eiminate the problem.
> Difficult to know which data exactly causes the crash as it was in the
> middle of loading when it crashed.
> I suspect however it was related to loading a CSV file - this caused my
> previous crash.
> I do understand that QGIS is in a state of constant development and crashes
> are inevitable.
> I will try to prevent future crashes by simplifying the initial import stage
> and  minimising the post-import data processing,
> Roy
> 2012/9/5 Noli Sicad <nsicad at gmail.com>
>> Try rebooting your system (i.e. turning off the computer and on again).
>> See if you can reproduce the crash again.
>> It might be good to attached the data that crash your system, if can
>> crash your system again.
>> Noli
>> On 9/5/12, Roy Marsh <roymarsh11 at gmail.com> wrote:
>> > My project has just crashed again while it was loading the data
>> > I have attached a screenshot of the error report, in case it means
>> > something to someone.
>> > This is serious. I was doing real work and I have no idea how to recover
>> > it.
>> > My future use of QGIS is in doubt
>> > Roy
> Qgis-user mailing list
