[Qgis-user] QGIS 1.8 crashed again
Bob and Deb bobdebm at gmail.com
Wed Sep 5 08:54:05 PDT 2012
Too bad there is no --debug option in qgis.
Is the osgeo4w build of qgis-dev a debug build?
On Sep 5, 2012 4:43 AM, "Nathan Woodrow" <madmanwoo at gmail.com> wrote:
> Roy,
> Did you happen to using the import delimited data plugin?  Was it
> enabled when you opened the project?
> - Nathan
> On Wed, Sep 5, 2012 at 9:35 PM, Roy Marsh <roymarsh11 at gmail.com> wrote:
> > Rebooting does not eiminate the problem.
> > Difficult to know which data exactly causes the crash as it was in the
> > middle of loading when it crashed.
> > I suspect however it was related to loading a CSV file - this caused my
> > previous crash.
> > I do understand that QGIS is in a state of constant development and
> crashes
> > are inevitable.
> > I will try to prevent future crashes by simplifying the initial import
> stage
> > and  minimising the post-import data processing,
> > Roy
> > 2012/9/5 Noli Sicad <nsicad at gmail.com>
> >> Try rebooting your system (i.e. turning off the computer and on again).
> >> See if you can reproduce the crash again.
> >> It might be good to attached the data that crash your system, if can
> >> crash your system again.
> >> Noli
> >> On 9/5/12, Roy Marsh <roymarsh11 at gmail.com> wrote:
> >> > My project has just crashed again while it was loading the data
> >> > I have attached a screenshot of the error report, in case it means
> >> > something to someone.
> >> > This is serious. I was doing real work and I have no idea how to
> recover
> >> > it.
> >> > My future use of QGIS is in doubt
> >> > Roy
> > Qgis-user mailing list
> > Qgis-user at lists.osgeo.org
> > http://lists.osgeo.org/mailman/listinfo/qgis-user
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20120905/fa854df6/attachment.html>
