[Qgis-user] Problems to display working window on MacOSX
Noli Sicad nsicad at gmail.com
Fri Sep 14 20:16:23 PDT 2012
Hi Jose,
Are you using the nightly build from http://qgis.dakotacarto.com ?
Larry mentioned this from QGIS-developer.
"Snow Leopard master nightly on your 64-bit-capable Macs:
You might see intermittent builds over the next few days, until I can
verify the nightly build script works on that older Core 2 Duo server
and that it reports the unit tests correctly."
It seems that the SL nightly build at the moment does work / run in
Core 2 Duo machine.
Noli
On 9/15/12, José Carlos Guerrero Antúnez <jcgantunez at gmail.com> wrote:
> Hi,
> I have problems with the window working on qgis, I can not displayed it
> correctly.
> OSX 10.6.8
> Qgis 1.8 updated.
> I'm working with an IMac10,1, Intel Core 2 duo
> What I con do?
> Regards
> Dr. José Carlos Guerrero
> Laboratorio de Desarrollo Sustentable y Gestión Ambiental del Territorio
> (LDSGAT)
> Instituto de Ecología y Ciencias Ambientales (IECA)
> Facultad de Ciencias
> Universidad de la República
> Montevideo-URUGUAY
