[Qgis-user] Problems to display working window on MacOSX
José Carlos Guerrero Antúnez
jcgantunez at gmail.com
Sat Sep 15 05:55:14 PDT 2012
Hi Noli,
I don't know if I'm using the nightly build from http://qgis.dakotacarto.com, I
downloaded qgis from Kingchaos web.
How do I know it?, sorry, my ignorance.
I have installed qgis on a MacBook Pro, Intel Core 2 Duo, it works
correctly.
And then, what do I can do? I download
qgis-nightly-build_snoleo.zip<http://qgis.dakotacarto.com/nightly/qgis-mac-nightly_snoleo.zip>
or
I have a little patience?
Thank you again.
Regards,
Jose C. Guerrero,
2012/9/15 Noli Sicad <nsicad at gmail.com>
> Hi Jose,
> Are you using the nightly build from http://qgis.dakotacarto.com ?
> Larry mentioned this from QGIS-developer.
> "Snow Leopard master nightly on your 64-bit-capable Macs:
> You might see intermittent builds over the next few days, until I can
> verify the nightly build script works on that older Core 2 Duo server
> and that it reports the unit tests correctly."
> It seems that the SL nightly build at the moment does work / run in
> Core 2 Duo machine.
> Noli
> On 9/15/12, José Carlos Guerrero Antúnez <jcgantunez at gmail.com> wrote:
> > Hi,
> > I have problems with the window working on qgis, I can not displayed it
> > correctly.
> > OSX 10.6.8
> > Qgis 1.8 updated.
> > I'm working with an IMac10,1, Intel Core 2 duo
> > What I con do?
> > Regards
> > Dr. José Carlos Guerrero
> > Laboratorio de Desarrollo Sustentable y Gestión Ambiental del Territorio
> > (LDSGAT)
> > Instituto de Ecología y Ciencias Ambientales (IECA)
> > Facultad de Ciencias
> > Universidad de la República
> > Montevideo-URUGUAY
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20120915/3658461d/attachment.html>
