[Qgis-user] Domains darstellen
Werner Macho werner.macho at gmail.com
Mon Sep 17 04:51:08 PDT 2012
Hi!
That sounds like my point on the wishlist
https://docs.google.com/document/d/1CTjrXWu0EJqLWcKU2ifBoQKPwXlZAkZnSzewq8zsamM/edit#heading=h.ggk1rwwhya4q
Point 3: Add Points along line aka "route labelling"
There is some "workaround" here
http://woostuff.wordpress.com/2012/08/05/generating-chainage-distance-nodes-in-qgis/
but it seems not to be meaned for the enduser ;)
So no - not in QGIS right now - but hopefully sometime
HTH
kind regards
Werner
On 09/17/2012 10:39 AM, carann00 wrote:
> Thank you Marco and Paolo,
> I never used plugins... I have to check how to use/install/import/etc. these
> two. ;-)
> Meanwhile in my .shp I could create a new attribute "length".
> According to my internet research, in ESRI is possible to display a
> "scale"..
> http://help.arcgis.com/de/arcgisdesktop/10.0/help/index.html#//00390000001n000000
> This is exactly what I need!
> In QGIS I found in Symbology/ Symbolproperties/"Markierungslinie" a similar
> feature. However, it is not possible to set an intervall-length for
> kilometer. Any Idea if there is something similar in QGIS?
> View this message in context: http://osgeo-org.1560.n6.nabble.com/Domains-darstellen-tp5001862p5002282.html
> Sent from the Quantum GIS - User mailing list archive at Nabble.com.
> Qgis-user mailing list
