[Qgis-user] Problems to display working window on MacOSX
José Carlos Guerrero Antúnez
jcgantunez at gmail.com
Mon Sep 17 11:04:27 PDT 2012
Hi William,
Thank you for your help. Now, I can work whithout problem.
Regards,
Jose C. Guerrero
2012/9/15 William Kyngesburye <woklist at kyngchaos.com>
> On Sep 15, 2012, at 7:55 AM, José Carlos Guerrero Antúnez wrote:
> > > OSX 10.6.8
> > > Qgis 1.8 updated.
> > > I'm working with an IMac10,1, Intel Core 2 duo
> Updated - do you mean you had a previous version of QGIS installed and you
> upgraded? There might be extra plugins from the old version that do not
> work in QGIS. There is a known problem of old plugins that use PyQwt will
> cause the new QGIS to crash, a couple of these are profiletool and
> valuetool.
> You can trash ~/Library/Preferences/org.qgis.QGIS.plist (that's in your
> home folder Library) and the next time you start QGIS all your extra
> plugins will be disabled (if QGIS still crashes, it's something else).
> Turn them on one by one in the plugin manager to find which one(s)
> crashes. Either update or delete the plugin(s). Valuetool has been
> updated for this problem but I have not heard about profiletool being
> updated.
> William Kyngesburye <kyngchaos*at*kyngchaos*dot*com>
> http://www.kyngchaos.com/
> "We are at war with them. Neither in hatred nor revenge and with no
> particular pleasure I shall kill every ___ I can until the war is over.
> That is my duty."
> "Don't you even hate 'em?"
> "What good would it do if I did? If all the many millions of people of the
> allied nations devoted an entire year exclusively to hating the ____ it
> wouldn't kill one ___ nor shorten the war one day."
> <Ha, ha> "And it might give 'em all stomach ulcers."
> - Tarzan, on war
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20120917/f0e1161e/attachment.html>
