[Qgis-user] NViz not starting
Saber Razmjooei saber.razmjooei at lutraconsulting.co.uk
Thu Sep 20 06:36:50 PDT 2012
If installing from OSGeo4W, ensure the tcl/tk library is installed.
Also, could you try and run it under GRASS itself.
Cheers
Saber
________________
Saber Razmjooei
Lutra Consulting
www.lutraconsulting.co.uk
On 20/09/2012 09:37, Jonathan Webb wrote:
> Hi,
> I'm exploring QGIS, having used ArcGis & MapInfo for years, but am
> having trouble. PC is Win XP SP3 32bit.
> I'm getting a problem with NVIZ - it won't start, with a message about
> not finding init.tcl etc.  There is an amount about this on the web
> but it is either too technical/not clear enough for me, or unresolved.
> One answer was to ensure that TCL was installed through OSGeo4W so I
> uninstalled/deleted as much of QGIS etc as I could find, then run two
> registry cleaners several times before restarting & downloading
> OSGeo4W.exe which also appears to have installed QGIS etc.
> Things looked hopeful when I clicked on the MSys & OSGeo4W links as I
> received no error messages. But I still get the same NVIZ error message.
> Are there any log files I should look for?
> I've looked in nviz2.2_script which appears to be invoked by NViz &
> also one of the init.tcl in various folders, but can't work out
> anything from these.
> Can anyone help please?
> Many thanks
> Jonathan
> J Webb GIS 07941 921905
> Qgis-user mailing list
This email and any files transmitted with it are confidential and intended solely for the use of the individual or entity to whom they are addressed.
If you have received this email in error please notify the system manager. This message contains confidential information and is intended only for the
individual named. If you are not the named addressee you should not disseminate, distribute or copy this e-mail. Please notify the sender immediately
by e-mail if you have received this e-mail by mistake and delete this e-mail from your system. If you are not the intended recipient you are notified
that disclosing, copying, distributing or taking any action in reliance on the contents of this information is strictly prohibited.
Whilst reasonable care has been taken to avoid virus transmission, no responsibility for viruses is taken and it is your responsibility to carry out
such checks as you feel appropriate.
Saber Razmjooei and Peter Wells trading as Lutra Consulting.
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20120920/5dbcebc8/attachment.html>
