[Qgis-user] Fwd: "Normal" mdb support possible for "normal" people?
Johan Nilsson joni8135 at gmail.com
Sun Sep 23 13:48:46 PDT 2012
According to this, ERSI recommend file geodatabase over personal geodatabas
and arcsde are for multiuser system and need additional software and
licenes, I tthink.
So If you only have Arcgis they recommend file database och personal
geodatabase, not ArcSDE. I think.
http://webhelp.esri.com/arcgisdesktop/9.2/index.cfm?topicname=types_of_geodatabases
2012/9/23 Andrea Peri <aperi2007 at gmail.com>
> Yes is true.
> Esri don't recommend the personal-gdb.
> Esri recommend the arcsdk
> Because the access db is slow and with size limit (2GB).
> The spatialite instead has not a size limit and is fast. :)
> But I guess there is another more important question:
> spatialite work in double precision indipendently by the extent of the DB.
> In the personal-geodatabase (9.1 version) is the extent of dataset is 10km
> there is a precision P1.
> If the extent of the dataset is 1000Km the precision is P2 with P2 worst
> than P1.
> Spatialite don't do this.
> Johan Nilsson <joni8135 at gmail.com>
> But ESRI does NOT recommend to use personal-geodatabases as i show in a
>> link, above. It's get slow around 500Mb and have a maximun limit of 2GB for
>> instance.
>> /Cheers
>>> I guess who buy an arcgis, should still use it. :))
>>> If an user is happy with the results of arcgis and its
>>> personal-geodatabse.
>>> AFAIK arcgis and personal-geodatabase, has a simpatic mechanism to
>>> transform the coords in a quantized value coords.
>>> It a curious mechanism perhpas the best an human can invent, but it has
>>> only a "little" problem.
>>> It change always the cords when an user share their dataset with other
>>> users having another geodatabse with different precision in it.
>>> If an user don't see a problem in this.
>>> I guess it is better still to use this wonderful product.
>>> I guess spatialite is not a good product for this users.
>>> Regards,
>>> Andrea Peri
>>> qwerty àèìòù
>>> Qgis-user mailing list
>>> Qgis-user at lists.osgeo.org
>>> http://lists.osgeo.org/mailman/listinfo/qgis-user
> Andrea Peri
> qwerty àèìòù
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20120923/74aa35a8/attachment.html>
