[Qgis-user] QT-Designer
Etienne Tourigny
etourigny.dev at gmail.com
Mon Sep 24 07:11:52 PDT 2012
2012/9/24 Bernd Vogelgesang <bernd.vogelgesang at gmx.de>:
> I don't think that the path you found is an installation of QTDesigner but
> rather the "connection" between qgis and the forms you create and load.
> I installed the QT4 Designer as part of a huge programm from Nokia, cause
> googling for that stuff didn't yield any other source.
> http://qt-project.org/downloads
> Its the QT Creator SDK which has 1.7 GB to download and with which you could
> program design all kinds of user interfaces. Somewhere hidden in the many
> things you can do there and which i do not understand at all, you find an
> option to create QT Designer User Form.
> Be sure to check QT Designer while installing, cause i missed that part and
> searched for ages for the QT Designer stuff, and only found out by
> installing again and then finding the checkbox and everything was there
> then.
Have you tried the online installer (15 MB)? Perhaps you can do a
minimal install (including designer), instead of the full installer
with everything.
> From that point on everything is quite easy, as you only have to drag new
> fields in your form and rename them according to your field names of your
> tabel.
> If anyone knows an easier way to get hands on the QT-Designer than
> installing this huge creator thing, it would be nice to be told about it.
> Greetz
> Bernd
> Am 24.09.2012 14:36, schrieb Sylvia Preuß:
> Dear list,
> how can I create a *.ui file with qt-designer? I want to create a new object
> with attributes and would like to use my own form to insert the attributes.
> C:\Programme\Quantum GIS Wroclaw\apps\Python27\sip\PyQt4\QtDesigner is
> installed. But I don’t know how to get it started.
> Postgis-Layer, Wroclaw
> Best regards
> Sylvia
> ________________________________
> Der E-Mail-Dienst des Oberbergischen Kreises dient ausschließlich der
> dienstlichen Kommunikation.
> Senden Sie deshalb keine E-Mails privaten Inhalts an E-Mail-Adressen des
> Oberbergischen Kreises.
> Es wird darauf hingewiesen, dass neben der Person, an die Ihre E-Mail
> gerichtet ist, auch deren Vertretung im Amt einen unmittelbaren Zugriff auf
> Ihre Nachricht hat. Für Berufsgeheimnisträger und besondere Funktionsträger
> gelten abweichende Regelungen.
> Es wird außerdem darauf hingewiesen, dass die Kommunikation per E-Mail o hne
> Authentifizierung und Verschlüsselung unsicher ist, da für unberechtigte
> Dritte grundsätzlich die Möglichkeit der Kenntnisnahme und Manipulation
> besteht.
> Es wird deshalb keine Verantwortung für den Inhalt dieser Nachricht
> übernommen, da eine Manipulation nicht ausgeschlossen werden kann.
> Obwohl alle angemessenen Vorkehrungen getroffen wurden, um sicherzustellen,
> dass Anlagen dieser E-Mail virusgeprüft sind, wird empfohlen, anhängende
> Dateien vor dem Öffnen durch Ihr eigenes Virus-Programm zu prüfen, da
> keinerlei Haftung für Schäden übernommen wird, die infolge etwaiger
> Software-Viren entstehen könnten.
> Der Inhalt dieser E-Mail ist ausschließlich für die bezeichnete Person
> bestimmt. Wenn Sie nicht der vorgesehene Adressat dieser E-Mail oder dessen
> Vertretung sein sollten, beachten Sie bitte, dass jede Form der
> Kenntnisnahme, Veröffentlichung, Vervielfältigung oder Weitergabe des
> Inhalts dieser E-Mail unzulässig ist. In diesem Fall wird darum gebeten,
> sich mit der absendenden Person der E-Mail in Verbindung zu setzen.
> Qgis-user mailing list
