[Qgis-user] build only QGIS Server on CentOS
Eduardo Kanegae eduardo.kanegae at gmail.com
Wed Sep 26 07:38:22 PDT 2012
hi ,
Is there any way to configure QGIS 1.8.0 source to be built only QGIS
Server feature? I'll not need QGIS desktop at this machine, only
server will be needed.
I'm on CentOS 6.2 trying to build it but after "ccmake" I got the error:
[ 83%] Built target compile_python_files
[ 83%] Generating analysis/sipanalysispart0.cpp,
analysis/sipanalysispart1.cpp, analysis/sipanalysispart2.cpp,
analysis/sipanalysispart3.cpp
sip: Usage: sip [-h] [-V] [-a file] [-c dir] [-d file] [-e] [-g] [-I
dir] [-j #] [-m file] [-p module] [-r] [-s suffix] [-t tag] [-w] [-x
feature] [-z file] [file]
make[2]: *** [python/analysis/sipanalysispart0.cpp] Error 1
make[1]: *** [python/CMakeFiles/python_module_qgis_analysis.dir/all] Error 2
make: *** [all] Error 2
here's my ccmake configuration screen:
 BINDINGS_GLOBAL_INSTALL          OFF
 BISON_EXECUTABLE                 /usr/bin/bison
 BUILD_TESTING                    ON
 CMAKE_BUILD_TYPE
 CMAKE_INSTALL_PREFIX             /usr/local
 DART_ROOT                        DART_ROOT-NOTFOUND
 ENABLE_TESTS                     ON
 EXPAT_INCLUDE_DIR                /usr/include
 EXPAT_LIBRARY                    /usr/lib64/libexpat.so
 FCGI_INCLUDE_DIR                 /usr/local/include
 FCGI_LIBRARY                     /usr/local/lib/libfcgi.so
 FLEX_EXECUTABLE                  /usr/bin/flex
 GDAL_CONFIG                      /usr/local/bin/gdal-config
 GDAL_CONFIG_PREFER_FWTOOLS_PAT   /bin_safe
 GDAL_CONFIG_PREFER_PATH          /bin
 GDAL_INCLUDE_DIR                 /usr/local/include
 GDAL_LIBRARY                     /usr/local/lib/libgdal.so
 GEOS_CONFIG                      /usr/local/bin/geos-config
 GEOS_CONFIG_PREFER_PATH          /bin
 GEOS_INCLUDE_DIR                 /usr/local/include
 GEOS_LIBRARY                     /usr/local/lib/libgeos_c.so
 GEOS_LIB_NAME_WITH_PREFIX        -lgeos_c
 GIT_MARKER                       GIT_MARKER-NOTFOUND
 GRASS_PREFIX
 PEDANTIC                         ON
 POSTGRESQL_PREFIX
 POSTGRES_CONFIG                  /usr/bin/pg_config
 POSTGRES_CONFIG_PREFER_PATH      /bin
 POSTGRES_INCLUDE_DIR             /usr/include
 POSTGRES_LIBRARY                 /usr/lib64/libpq.so
 PROJ_INCLUDE_DIR                 /usr/local/include
 PROJ_LIBRARY                     /usr/local/lib/libproj.so
 PYRCC4_PROGRAM                   /usr/bin/pyrcc4
 PYTHON_LIBRARY                   /usr/lib64/libpython2.6.so
 PYUIC4_PROGRAM                   /usr/bin/pyuic4
 QT_QMAKE_EXECUTABLE              /usr/bin/qmake-qt4
 QWT_INCLUDE_DIR                  /usr/include/qwt
 QWT_LIBRARY                      /usr/lib64/libqwt.so
 SPATIALINDEX_INCLUDE_DIR         /usr/local/include/spatialindex
 SPATIALINDEX_LIBRARY             /usr/local/lib/libspatialindex.so
 SPATIALITE_INCLUDE_DIR           /usr/local/include
 SPATIALITE_LIBRARY               /usr/local/lib/libspatialite.so
 SQLITE3_INCLUDE_DIR              /usr/include
 SQLITE3_LIBRARY                  /usr/lib64/libsqlite3.so
 TXT2TAGS_EXECUTABLE              /usr/bin/txt2tags
 WITH_APIDOC                      OFF
 WITH_ASTYLE                      OFF
 WITH_BINDINGS                    ON
 WITH_DESKTOP                     OFF
 WITH_GLOBE                       OFF
 WITH_GRASS                       ON
 WITH_INTERNAL_QWTPOLAR           ON
 WITH_INTERNAL_SPATIALITE         OFF
 WITH_MAPSERVER                   ON
 WITH_POSTGRESQL                  ON
 WITH_PYSPATIALITE                OFF
 WITH_QTMOBILITY                  OFF
 WITH_SPATIALITE                  ON
 WITH_TXT2TAGS_PDF                OFF
 _find_lib_python_py
/usr/local/src/qgis-1.8.0/cmake/FindLibPython.py
 _find_pyqt_py                    /usr/local/src/qgis-1.8.0/cmake/FindPyQt.py
 _find_sip_py                     /usr/local/src/qgis-1.8.0/cmake/FindSIP.py
 _python_compile_py
/usr/local/src/qgis-1.8.0/cmake/PythonCompile.py
thanks in advance for any help.
Eduardo Patto Kanegae
http://www.webmapit.com | @webmapit
