[Qgis-user] SVG export New Symbology [was Text symbols]
Alex Mandel
tech_dev at wildintellect.com
Fri Sep 28 11:21:13 PDT 2012
On 09/28/2012 12:57 AM, Peter Schürch wrote:
> Hi Stephen
> You can place a buffer around the text, that enhances readability a lot. If you want to export your map to pdf or svg you should use new-style labelling (the Icon with the letters "ABC" on the toolbar), otherwise export fails. New-style labelling allows you to place labels parallel to lines, could be quite useful too.
Last time I checked the results with old Labeling and old Symbology were
more compatible with SVG export. Specifically the New stuff didn't keep
text as text which is a problem for SVG cleanup.
Did this change in 1.8?
Thanks,
Alex
