[Qgis-user] build only QGIS Server on CentOS
Andreas Neumann
a.neumann at carto.net
Wed Sep 26 08:01:08 PDT 2012
hi,
one warning though: if you need SVG symbols (for patterns, markers or
symbols) you will need an XServer. This is a limitation/dependency of
the qtsvg classes.
You can install a mini XServer, like XVnc
Good luck,
Andreas
Am 26.09.2012 16:38, schrieb Eduardo Kanegae:
> hi ,
> Is there any way to configure QGIS 1.8.0 source to be built only QGIS
> Server feature? I'll not need QGIS desktop at this machine, only
> server will be needed.
> I'm on CentOS 6.2 trying to build it but after "ccmake" I got the error:
> [ 83%] Built target compile_python_files
> [ 83%] Generating analysis/sipanalysispart0.cpp,
> analysis/sipanalysispart1.cpp, analysis/sipanalysispart2.cpp,
> analysis/sipanalysispart3.cpp
> sip: Usage: sip [-h] [-V] [-a file] [-c dir] [-d file] [-e] [-g] [-I
> dir] [-j #] [-m file] [-p module] [-r] [-s suffix] [-t tag] [-w] [-x
> feature] [-z file] [file]
> make[2]: *** [python/analysis/sipanalysispart0.cpp] Error 1
> make[1]: *** [python/CMakeFiles/python_module_qgis_analysis.dir/all] Error 2
> make: *** [all] Error 2
> here's my ccmake configuration screen:
> BINDINGS_GLOBAL_INSTALL OFF
> BISON_EXECUTABLE /usr/bin/bison
> BUILD_TESTING ON
> CMAKE_BUILD_TYPE
> CMAKE_INSTALL_PREFIX /usr/local
> DART_ROOT DART_ROOT-NOTFOUND
> ENABLE_TESTS ON
> EXPAT_INCLUDE_DIR /usr/include
> EXPAT_LIBRARY /usr/lib64/libexpat.so
> FCGI_INCLUDE_DIR /usr/local/include
> FCGI_LIBRARY /usr/local/lib/libfcgi.so
> FLEX_EXECUTABLE /usr/bin/flex
> GDAL_CONFIG /usr/local/bin/gdal-config
> GDAL_CONFIG_PREFER_FWTOOLS_PAT /bin_safe
> GDAL_CONFIG_PREFER_PATH /bin
> GDAL_INCLUDE_DIR /usr/local/include
> GDAL_LIBRARY /usr/local/lib/libgdal.so
> GEOS_CONFIG /usr/local/bin/geos-config
> GEOS_CONFIG_PREFER_PATH /bin
> GEOS_INCLUDE_DIR /usr/local/include
> GEOS_LIBRARY /usr/local/lib/libgeos_c.so
> GEOS_LIB_NAME_WITH_PREFIX -lgeos_c
> GIT_MARKER GIT_MARKER-NOTFOUND
> GRASS_PREFIX
> PEDANTIC ON
> POSTGRESQL_PREFIX
> POSTGRES_CONFIG /usr/bin/pg_config
> POSTGRES_CONFIG_PREFER_PATH /bin
> POSTGRES_INCLUDE_DIR /usr/include
> POSTGRES_LIBRARY /usr/lib64/libpq.so
> PROJ_INCLUDE_DIR /usr/local/include
> PROJ_LIBRARY /usr/local/lib/libproj.so
> PYRCC4_PROGRAM /usr/bin/pyrcc4
> PYTHON_LIBRARY /usr/lib64/libpython2.6.so
> PYUIC4_PROGRAM /usr/bin/pyuic4
> QT_QMAKE_EXECUTABLE /usr/bin/qmake-qt4
> QWT_INCLUDE_DIR /usr/include/qwt
> QWT_LIBRARY /usr/lib64/libqwt.so
> SPATIALINDEX_INCLUDE_DIR /usr/local/include/spatialindex
> SPATIALINDEX_LIBRARY /usr/local/lib/libspatialindex.so
> SPATIALITE_INCLUDE_DIR /usr/local/include
> SPATIALITE_LIBRARY /usr/local/lib/libspatialite.so
> SQLITE3_INCLUDE_DIR /usr/include
> SQLITE3_LIBRARY /usr/lib64/libsqlite3.so
> TXT2TAGS_EXECUTABLE /usr/bin/txt2tags
> WITH_APIDOC OFF
> WITH_ASTYLE OFF
> WITH_BINDINGS ON
> WITH_DESKTOP OFF
> WITH_GLOBE OFF
> WITH_GRASS ON
> WITH_INTERNAL_QWTPOLAR ON
> WITH_INTERNAL_SPATIALITE OFF
> WITH_MAPSERVER ON
> WITH_POSTGRESQL ON
> WITH_PYSPATIALITE OFF
> WITH_QTMOBILITY OFF
> WITH_SPATIALITE ON
> WITH_TXT2TAGS_PDF OFF
> _find_lib_python_py
> /usr/local/src/qgis-1.8.0/cmake/FindLibPython.py
> _find_pyqt_py /usr/local/src/qgis-1.8.0/cmake/FindPyQt.py
> _find_sip_py /usr/local/src/qgis-1.8.0/cmake/FindSIP.py
> _python_compile_py
> /usr/local/src/qgis-1.8.0/cmake/PythonCompile.py
> thanks in advance for any help.
> Eduardo Patto Kanegae
> http://www.webmapit.com | @webmapit
> Qgis-user mailing list
