[Qgis-user] build only QGIS Server on CentOS
Eduardo Kanegae eduardo.kanegae at gmail.com
Wed Sep 26 08:16:57 PDT 2012
Thanks Jürgen,
solved:
[100%] Generating moc_qgsbench.cxx
Scanning dependencies of target qgis_bench
[100%] Building CXX object tests/bench/CMakeFiles/qgis_bench.dir/main.cpp.o
[100%] Building CXX object tests/bench/CMakeFiles/qgis_bench.dir/qgsbench.cpp.o
tests/bench/CMakeFiles/qgis_bench.dir/moc_qgsbench.cxx.o
Linking CXX executable ../../output/bin/qgis_bench
[100%] Built target qgis_bench
Eduardo
2012/9/26 Jürgen E. <jef at norbit.de>:
> Hi Eduardo,
> On Wed, 26. Sep 2012 at 11:38:22 -0300, Eduardo Kanegae wrote:
>> I'm on CentOS 6.2 trying to build it but after "ccmake" I got the error:
>> [ 83%] Built target compile_python_files
>> [ 83%] Generating analysis/sipanalysispart0.cpp,
>> analysis/sipanalysispart1.cpp, analysis/sipanalysispart2.cpp,
>> analysis/sipanalysispart3.cpp
>>  WITH_BINDINGS                    ON
> Switch that one off to disable the (sip) bindings - it's not used in the server
> anyway.
> Jürgen
> Jürgen E. Fischer         norBIT GmbH               Tel. +49-4931-918175-31
> Dipl.-Inf. (FH)           Rheinstraße 13            Fax. +49-4931-918175-50
> Software Engineer         D-26506 Norden               http://www.norbit.de
> committ(ed|ing) to Quantum GIS                         IRC: jef on FreeNode
> norBIT Gesellschaft fuer Unternehmensberatung und Informationssysteme mbH
> Rheinstrasse 13, 26506 Norden
> GF: Jelto Buurman, HR: Amtsgericht Emden, HRB 5502
> Qgis-user mailing list
