[Qgis-user] First time here
Micha Silver micha at arava.co.il
Sun Sep 30 02:17:37 PDT 2012
On 30/09/2012 10:28, Paolo Cavallini wrote:
> Il 29/09/2012 23:13, Micha Silver ha scritto:
>> the '-burn' option to set a value for the raster. (The same command exists in the
>> QGIS Raster menu, but allows only to choose an attrib column from the shapefile for
>> the raster cell values. Not a static value, as you want). So, from the command line:
> Could you please fill a ticket? It is an easy fix.
> Thanks.
Sure, entered as:
http://hub.qgis.org/issues/6436
Micha Silver
052-3665918
