[Qgis-user] Server map path
    Andreas Neumann
    a.neumann at carto.net
    Sun Sep 30 08:02:26 PDT 2012
Hi Anita,
You can only use absolute paths for setting a project in QGIS server.
Can you explain why you want to use relative paths and what should be
the reference. Without knowing your ideas you have in mind I fail to see
the reason for relative paths. But maybe there is a use case.
Andreas
Am 30.09.2012 12:38, schrieb Anita Graser:
> Hi,
> I have a QGIS Server with multiple project files. I can specify the
> desired project using the map parameter but it seems like it only works
> using absolute paths. If I try relative paths, it throws errors about
> not being able to locate the file. Is there a way to use relative paths
> too?
> Best wishes,
> Anita
> Qgis-user mailing list
