[Qgis-user] QGis for bird surveys
Lynkos lynkosmail at gmail.com
Wed Apr 3 07:04:55 PDT 2013
Alexandre
, thanks :-). I'll try your suggestion and let you know if I can make it
work.
2013/4/3 Alexandre Neto <senhor.neto at gmail.com>
> For each new record you need to add a new Point to your shapefile. If you
> need to enter the coordinates by hand, then you should take a look at the
> numerical digitalize plugin. After the point is added you can then edit the
> rest of your attributes.
> If you have too many new observations already in a spreadsheet, then you
> can do in another way:
> - Create a temporary shapefile from the new spreadsheet, making sure that
> its attributes are the same as you main shapefile;
> - Add it to map canvas;
> - Select that layer and copy all its features (points) using the select by
> rectangle or directly on attribute table and copy them to clipboard.
> - Select the main shapefile, star editing (the pencil icon), and paste the
> features from clipboars.
> If everything went well, and the layers attributes match, you will get all
> the new bird sighting in the main shapefile.
> Still, the best would be to directly input the sightings on the shapefile.
> Hope it helps,
> Alexandre Neto
> On Wed, Apr 3, 2013 at 11:18 AM, Lynkos <lynkosmail at gmail.com> wrote:
>> ... to modify the data, yes in fact that's what I'm doing. But to ADD a
>> new record from the coordinate data? Am I missing an "add" button somewhere?
>> 2013/4/3 Paolo Cavallini <cavallini at faunalia.it>
>>> -----BEGIN PGP SIGNED MESSAGE-----
>>> Hash: SHA1
>>> Il 03/04/2013 12:05, Lynkos ha scritto:
>>> > Thanks for answering so quickly Paolo.
>>> > Adding the data directly to the imported shapefile is exactly what I
>>> would like to
>>> > do. I'm sure it's incredibly simple, but I just can't figure out how,
>>> Sarah.
>>> Just click on the Pen button, start editing.
>>> All the best.
>>> Paolo Cavallini - Faunalia
>>> www.faunalia.eu
>>> Full contact details at www.faunalia.eu/pc
>>> Nuovi corsi QGIS e PostGIS: http://www.faunalia.it/calendario
>>> -----BEGIN PGP SIGNATURE-----
>>> Version: GnuPG v1.4.12 (GNU/Linux)
>>> Comment: Using GnuPG with Mozilla - http://enigmail.mozdev.org/
>>> iEYEARECAAYFAlFcAC0ACgkQ/NedwLUzIr5FewCfXdEjgOu6QniXiEN6mwABPgFX
>>> dM8An2UQpI9hHhsb/3zPYp41a/wsydXi
>>> =IvdX
>>> -----END PGP SIGNATURE-----
>>> Qgis-user mailing list
>>> Qgis-user at lists.osgeo.org
>>> http://lists.osgeo.org/mailman/listinfo/qgis-user
>> Con altri occhi - parole e immagini dalla parte della natura
>> www.lynkos.net
www.lynkos.net
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20130403/292650d5/attachment.html>
