[Qgis-user] QGis for bird surveys
Albin Blaschka
albin.blaschka at standortsanalyse.net
Wed Apr 3 07:34:30 PDT 2013
Hello!
Maybe a look into the manual would also help...
http://www.qgis.org/en/documentation.html
and the How-to pages (linked from the above mentioned page):
http://hub.qgis.org/projects/quantum-gis/wiki/How_do_I_do_that_in_QGIS
HTH,
Albin
Am 03.04.2013 16:04, schrieb Lynkos:
> Alexandre
> , thanks :-). I'll try your suggestion and let you know if I can make it
> work.
> 2013/4/3 Alexandre Neto <senhor.neto at gmail.com
> <mailto:senhor.neto at gmail.com>>
> For each new record you need to add a new Point to your shapefile.
> If you need to enter the coordinates by hand, then you should take a
> look at the numerical digitalize plugin. After the point is added
> you can then edit the rest of your attributes.
> If you have too many new observations already in a spreadsheet, then
> you can do in another way:
> - Create a temporary shapefile from the new spreadsheet, making sure
> that its attributes are the same as you main shapefile;
> - Add it to map canvas;
> - Select that layer and copy all its features (points) using the
> select by rectangle or directly on attribute table and copy them to
> clipboard.
> - Select the main shapefile, star editing (the pencil icon), and
> paste the features from clipboars.
> If everything went well, and the layers attributes match, you will
> get all the new bird sighting in the main shapefile.
> Still, the best would be to directly input the sightings on the
> shapefile.
> Hope it helps,
> Alexandre Neto
> On Wed, Apr 3, 2013 at 11:18 AM, Lynkos <lynkosmail at gmail.com
> <mailto:lynkosmail at gmail.com>> wrote:
> ... to modify the data, yes in fact that's what I'm doing. But
> to ADD a new record from the coordinate data? Am I missing an
> "add" button somewhere?
> 2013/4/3 Paolo Cavallini <cavallini at faunalia.it
> <mailto:cavallini at faunalia.it>>
> -----BEGIN PGP SIGNED MESSAGE-----
> Hash: SHA1
> Il 03/04/2013 12:05, Lynkos ha scritto:
> > Thanks for answering so quickly Paolo.
> > Adding the data directly to the imported shapefile is
> exactly what I would like to
> > do. I'm sure it's incredibly simple, but I just can't
> figure out how, Sarah.
> Just click on the Pen button, start editing.
> All the best.
> Paolo Cavallini - Faunalia
> www.faunalia.eu <http://www.faunalia.eu>
> Full contact details at www.faunalia.eu/pc
> <http://www.faunalia.eu/pc>
> Nuovi corsi QGIS e PostGIS: http://www.faunalia.it/calendario
> -----BEGIN PGP SIGNATURE-----
> Version: GnuPG v1.4.12 (GNU/Linux)
> Comment: Using GnuPG with Mozilla - http://enigmail.mozdev.org/
> iEYEARECAAYFAlFcAC0ACgkQ/NedwLUzIr5FewCfXdEjgOu6QniXiEN6mwABPgFX
> dM8An2UQpI9hHhsb/3zPYp41a/wsydXi
> =IvdX
> -----END PGP SIGNATURE-----
> Qgis-user mailing list
> Qgis-user at lists.osgeo.org <mailto:Qgis-user at lists.osgeo.org>
> Con altri occhi - parole e immagini dalla parte della natura
> www.lynkos.net <http://www.lynkos.net>
| Albin Blaschka, Mag.rer.nat.
| Etrichstrasse 26, A-5020 Salzburg
| * www.albinblaschka.info * www.thinkanimal.info *
| - It's hard to live in the mountains, hard but not hopeless!
