[Qgis-user] QGis for bird surveys
Goyo goyodiaz at gmail.com
Wed Apr 3 09:11:38 PDT 2013
2013/4/3 Rudi von Staden <rudivs at gmail.com>
> If this is the only application you have, and you only need to add data
> periodically, it might be easiest to maintain the data in Excel and just
> append the new records there. You can then import each time and recreate
> the shapefile. If it's important to maintain a consistent layer style, you
> can save the style as a qml file and then just load it again each time you
> do a new import. Might be easier than select/copy/edit/paste each time, and
> the data will probably be in a format you're more familiar with.
I used to follow a similar workflow for some time but instead of a
shapefile I used a plain text file so I just had to copy from the
spreadsheet and paste into the text file after updates (exporting as csv
would work too). It had about 2000 records when I switched to spatialite
and it was working quite well.
Goyo
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20130403/b24166d8/attachment.html>
