[Qgis-user] QGis for bird surveys
Lynkos
lynkosmail at gmail.com
Fri Apr 5 01:12:57 PDT 2013
Thanks Richard for your reply. I had in fact used the osgeo4w installer,
and tried using it again to reinstall, but with no luck. Then thanks to
your useful link, I found that the two lib elements necessary are not
downloaded and installed by default, but have to be selected manually using
the advanced installation function. I've now installed them and it works
fine. I have to resolve a few problems with data incompatibility, but looks
like it may well be the way to go. Thanks again, Sarah.
2013/4/5 Richard Duivenvoorde <rdmailings at duif.net>
> Hi,
> easiest way to have a QGIS on windows and be able to install common python
> libs needed for QGIS plugins is NOT to use the windows/msi installer, but
> the osgeo4w installer. While a little quirky for windows users, it makes it
> a lot easier to eg install QGIS with oracle, or gdb working (AND install
> the python xlw and xlrd, to make xytools work :-) )
> I've written something down here for this:
> http://www.qgis.nl/2012/06/20/**qgis-installeren-via-osgeo4w/?**lang=en<http://www.qgis.nl/2012/06/20/qgis-installeren-via-osgeo4w/?lang=en>
> or http://gis-lab.info/qa/qgis-**osgeo4w.html<http://gis-lab.info/qa/qgis-osgeo4w.html>
> (if you are on Windows7 you have to run the setup.exe as Administrator!)
> Which is good readable with Google Translate for everybody:
> http://translate.google.com/**translate?sl=auto&tl=en&js=n&**
> prev=_t&hl=nl&ie=UTF-8&layout=**2&eotf=1&u=http%3A%2F%2Fgis-**
> lab.info%2Fqa%2Fqgis-osgeo4w.**html&act=url<http://translate.google.com/translate?sl=auto&tl=en&js=n&prev=_t&hl=nl&ie=UTF-8&layout=2&eotf=1&u=http%3A%2F%2Fgis-lab.info%2Fqa%2Fqgis-osgeo4w.html&act=url>
> Regards,
Con altri occhi - parole e immagini dalla parte della natura
www.lynkos.net
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20130405/937994f0/attachment.html>
