[Qgis-user] Geoprocessing - Intersect points within Ploygon
Saber Razmjooei saber.razmjooei at lutraconsulting.co.uk
Fri Apr 5 07:28:56 PDT 2013
One way of doing it, is to use:
Vector > Research tools > Select by location
Once the points are selected, you can save them as a new shapefile.
Hope that helps.
Cheers
Saber
From: qgis-user-bounces at lists.osgeo.org [mailto:qgis-user-bounces at lists.osgeo.org] On Behalf Of Gibbons, John
Sent: 05 April 2013 15:02
To: 'qgis-user at lists.osgeo.org'
Subject: [Qgis-user] Geoprocessing - Intersect points within Ploygon
I'm try to create a list of points that exist within polygons. I have a delimited text layer for the points, and a shape file of polygons.
I've used Geoprocessing, Intersect off the Vector menu, specified the point layer first and polygon layer second. Although it creates a shape file, it has nothing in the resulting attribute table. I've tried different point and layer files, but still had no results.
I notice that I can carry out an intersect between two polygon layers, in this case, the attribute table has results.
I converted my point layer to to a shape file, ran the intersect again, but still no output.
There are points in the polygons(!), and the CRS match.
Can anyone advise?
DISCLAIMER: The information contained in this communication/message from John.Gibbons at salford.gov.uk sent on Fri Apr  5 15:01:58 2013 is confidential and may be legally privileged. It is intended solely for the addressee(s) qgis-user at lists.osgeo.org
Access to this message by anyone else is unauthorised. If you are not the intended recipient, any disclosure, copying, or distribution of the message, or any action or omission taken by you in reliance on it, is prohibited and may be unlawful.
As a public body, Salford City Council may be required to disclose this email [or any response to it] under the Freedom of Information Act 2000, unless the information in it is covered by one of the exemptions in the Act.
Please immediately contact the sender, John.Gibbons at salford.gov.uk if you have received this message in error.
For the full disclaimer please access http://www.salford.gov.uk/e-mail.  Thank you.
This email and any files transmitted with it are confidential and intended solely for the use of the individual or entity to whom they are addressed.
If you have received this email in error please notify the system manager. This message contains confidential information and is intended only for the
individual named. If you are not the named addressee you should not disseminate, distribute or copy this e-mail. Please notify the sender immediately
by e-mail if you have received this e-mail by mistake and delete this e-mail from your system. If you are not the intended recipient you are notified
that disclosing, copying, distributing or taking any action in reliance on the contents of this information is strictly prohibited.
Whilst reasonable care has been taken to avoid virus transmission, no responsibility for viruses is taken and it is your responsibility to carry out
such checks as you feel appropriate.
Saber Razmjooei and Peter Wells trading as Lutra Consulting.
