[Qgis-user] struggling with postgresql
Jesus Munoz Serrano
jesusmunozserrano at gmail.com
Sat Apr 6 03:00:46 PDT 2013
Hi everybody,
Sorry for asking about postgresql here. Maybe is not adequate at all but since I want it for spatial uses I thought it could be relevant. I've been researching a lot on the internet but I couldn't solve the issue.
I've installed the postgres.app and pgadmin III on my computer and I'm trying to create a database on the terminal (I know I can do it on pgAdmin III but I would like to learn the terminal way as well) and every attempt looks unsuccessful.
I have change my path to use the postgress.app instead the built one through:
PATH="/Applications/Postgres.app/Contents/MacOS/bin:$PATH"
First, when I enter $ psql in the terminal it returns:
psql: FATAL: role "xusto" does not exist (where xusto is my system username)
Researching on the web I found that is due to conflict between both copies of postgresql and that I have to connect via:
psql -h localhost -U postgres
So far so good. When I enter this command it returns me the following:
psql (9.0.10, server 9.1.8)
WARNING: psql version 9.0, server version 9.1.
Some psql features might not work.
Type "help" for help.
postgres=#
Even with the warning message I understand that I'm connected to postgresql. Nonetheless, when I enter "CREATE DATABASE mydb" it doesn't return anything.
Is there anything I am doing wrong?
Also I wanted to ask how can I do it to install the PostGIS?
Sorry again and thank you very much!
- jesus
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20130406/bae2e2cb/attachment.html>
