[Qgis-user] struggling with postgresql
William Kyngesburye woklist at kyngchaos.com
Sat Apr 6 08:52:11 PDT 2013
On Apr 6, 2013, at 5:00 AM, Jesus Munoz Serrano wrote:
> Hi everybody,
> Sorry for asking about postgresql here. Maybe is not adequate at all but since I want it for spatial uses I thought it could be relevant. I've been researching a lot on the internet but I couldn't solve the issue.
> I've installed the postgres.app and pgadmin III on my computer and I'm trying to create a database on the terminal (I know I can do it on pgAdmin III but I would like to learn the terminal way as well) and every attempt looks unsuccessful.
> I have change my path to use the postgress.app instead the built one through:
> 			PATH="/Applications/Postgres.app/Contents/MacOS/bin:$PATH"
> First, when I enter 	$ psql	in the terminal it returns:
> 			psql: FATAL:  role "xusto" does not exist      (where xusto is my system username)
> Researching on the web I found that is due to conflict between both copies of postgresql and that I have to connect via:
> 			psql -h localhost -U postgres
> So far so good. When I enter this command it returns me the following:
> 				psql (9.0.10, server 9.1.8)
> 				WARNING: psql version 9.0, server version 9.1.
>     						     Some psql features might not work.
> 				Type "help" for help.
> 				postgres=#
> Even with the warning message I understand that I'm connected to postgresql. Nonetheless, when I enter 	"CREATE DATABASE mydb" it doesn't return anything.
> Is there anything I am doing wrong?
Indeed this is all just a Postgres question.  Better to ask in appropriate postgres discussion places.
I have not used either Apple's bundled Postgres or the EnterpriseDB Postgres (I think that's what the Postgres.app is).  Another place to ask is EnterpriseDB (if that's what you have installed).
> Also I wanted to ask how can I do it to install the PostGIS?
Also a question better for another list - PostGIS user.  But a quick answer:
If you are running Apple's Postgres server, then you must compile PostGIS yourself (see postgis list and docs).  If you are running EnterpriseDB Postgres server, I think they have a built extension to install.  You'd have to ask them.
> Sorry again and thank you very much!
> - jesus
> Qgis-user mailing list
William Kyngesburye <kyngchaos*at*kyngchaos*dot*com>
http://www.kyngchaos.com/
"Those people who most want to rule people are, ipso-facto, those least suited to do it."
- A rule of the universe, from the HitchHiker's Guide to the Galaxy
