[Qgis-user] Event layer plugin linear referncing
Steve Morgan steve.morgan1 at earthlink.net
Sun Apr 7 12:04:26 PDT 2013
I'm new to this forum so forgive me if this is mis-directed.  I recently
downloaded and tried to use the above plugin from the Qgis repository but am
having problems so I'm hoping someone out there can help.  I didn't see any
help files with the plugin so I sent a message to the author Mr. Batlogg but
I'm not sure if that'll get through as he's not the maintainer so I thought
I'd ask here as well in case someone has used this plugin.  It looks really
neat but I can't get it to work.  Transcript of my message describing the
issue is
________________________________________________________________________________________
My use case is very simple as follows:
    I have a shp file (ROUTES.shp) representing road segments which are a
layer within QGIS.  Each segment has a ROUTE_NAME attribute.   I wish to
create points along these segments where EVENTS occur.
    The EVENTS are contained in a  csv file with a ROUTE_NAME and MILEPOINT
column.  The csv file contains a row for each event that occurs, each having
a ROUTE_NAME and MILEPOINT column.  The MILEPOINT values correspond to a
mileage measurement along the ROUTES geometry as in mile measurements.
Based on my understanding of the architecture of QGIS which is 2.5D, it has
no support for a true "M" attribute and hence your plugin relies on the
z-coordinate for the "M".  If that is the case then I suspect that perhaps
I've not correctly set the z coordinate within the shp file but I see no way
within QGIS to review or adjust it.  I believe it is set since I can export
data as kml and the z coordinate appears to be the desired "M" as the length
is depicted as an elevation.  Perhaps this is the root of my problem.
My other assumption is that a shp is satisfactory for the Line Layer and a
csv acceptable for the Event Layer.  If that's OK then perhaps there is a
sensitivity to attribute formatting (ie integer, string, etc) that I've
overlooked.
I noticed the plugin has been downloaded quite a few times so I hope
somebody here may be able to help.  Any pointers on this would be greatly
appreciated and, again, forgive me if this is not appropriate.
Best Regards,
Steve Morgan
View this message in context: http://osgeo-org.1560.n6.nabble.com/Event-layer-plugin-linear-referncing-tp5045084.html
Sent from the Quantum GIS - User mailing list archive at Nabble.com.
