[Qgis-user] How define the "other" condition on a classification render
Alexandre Neto senhor.neto at gmail.com
Wed Apr 17 02:24:13 PDT 2013
You should be.
I tested myself and I believe you found a bug.
You should be able to add a new class without any value, and all values
outside the existing categories should be rendered with that symbology.
Thats how it works in 1.8.
I'm not being able to open qgis.org (probably is under maintenance), but if
there is no issue ticket for this problem, we should create one.
Alexandre Neto
On Tue, Apr 16, 2013 at 10:15 PM, Andrea Peri <aperi2007 at gmail.com> wrote:
> Hi,
> I'm using the qgis-dev version of qgis.
> Is possible to define the 'other values' condition in the
> "categorized" style ?
> Thx
> Andrea Peri
> qwerty àèìòù
> Qgis-user mailing list
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20130417/630b1309/attachment.html>
