[Qgis-user] How define the "other" condition on a classification render
Andrea Peri aperi2007 at gmail.com
Wed Apr 17 02:42:31 PDT 2013
I have fill a ticket with a sample to show how  a map of qgis 1.8.0 if lost
on a qgis 1.9.0 after an import.
http://hub.qgis.org/issues/7630
2013/4/17 Alexandre Neto <senhor.neto at gmail.com>
> You should be.
> I tested myself and I believe you found a bug.
> You should be able to add a new class without any value, and all values
> outside the existing categories should be rendered with that symbology.
> Thats how it works in 1.8.
> I'm not being able to open qgis.org (probably is under maintenance), but
> if there is no issue ticket for this problem, we should create one.
> Alexandre Neto
> On Tue, Apr 16, 2013 at 10:15 PM, Andrea Peri <aperi2007 at gmail.com> wrote:
>> Hi,
>> I'm using the qgis-dev version of qgis.
>> Is possible to define the 'other values' condition in the
>> "categorized" style ?
>> Thx
>> Andrea Peri
>> qwerty àèìòù
>> Qgis-user mailing list
>> http://lists.osgeo.org/mailman/listinfo/qgis-user
Andrea Peri
qwerty àèìòù
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20130417/83ba9c64/attachment.html>
