[Qgis-user] csv point file to dxf
Paul Lens paul.lens at gmx.com
Fri Apr 19 00:43:11 PDT 2013
I do'nt know about converting a 3D csv to a shapefile.
About converting shp to dxf 3D, I see in my notes that ogr2ogr can
export  Z values to a dxf file.
It works fine for points.
For polylines, it just saves one Z value per polyline, thus for the
whole polyline not per vertex.
gvSig is able to save polylines to dxf with Z values per vertex.
I do not know how the grass command  "v.out.dxf" exports 3D shapefiles.
Hope this helps,
Paul
Le 18/04/2013 10:49, Paul Haakma a écrit :
> Hi All
> Can anyone advise on a way to import an 'x,y,z' csv point file and
> then export those points to a dxf retaining the elevation (z) data?
> I've seen several comments on the web saying that QGIS doesn't export
> vector elevation data, but then I discovered that the following *does*
> work: start with a 3d dxf (e.g. points that have x,y,z coordinates),
> import, save as a shapefile, re-import that shapefile and re-export as
> a new dxf. The resulting dxf still has the z data.
> This demonstrates that QGIS has the ability to create and read a 2.5D
> shapefile, and also read and create a 3d dxf, I just can't seem to
> achieve this when starting with a simple csv file.
> Any ideas?
> -Paul
> Qgis-user mailing list
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20130419/2aa2f32d/attachment.html>
