[Qgis-user] How to select single features that are below others
Alexandre Neto senhor.neto at gmail.com
Fri Apr 19 02:34:25 PDT 2013
Hello there,
I have some overlaid line features. I'm trying to manually select and
delete the ones that don't make sense.
If I use the "select feature" it only select the top feature. Is there a
easy way to select the features below?
My workaround is using the rectangle selection tool to select all overlaid
features, use the Itembrowser Plugin to browse through the selected
features and the attribute table to select the ones I want o delete.
Thanks,
Alexandre Neto
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20130419/b4d8531c/attachment.html>
