[Qgis-user] Error when using SAGA & SEXTANTE with QGIS 1.9
Victor Olaya
volayaf at gmail.com
Sat Apr 20 09:48:13 PDT 2013
Now it is working fine...but you are passing a cellsize of 0...that
doesn't make too much sense :-) That's why SAGA cannot produce any
output
Having 0 as de default value doesn't make much sense, so I have
changed it. Enter a better value there and it should work...
Cheers
Victor
2013/4/20 Nyx <nyxynyx at gmail.com>:
> "saga_cmd --v" says its SAGA 2.1.0. I've changed to SAGA 2.0.8, "saga_cmd
> -v" shows SAGA 2.0.8 and now I'm getting different errors when trying to do
> IDW.
> SAGA execution console output
> C:\>set SAGA=C:\Program Files (x86)\SAGA-GIS
> C:\>set SAGA_MLB=C:\Program Files (x86)\SAGA-GIS\modules
> C:\>PATH=PATH;C:\Program Files (x86)\SAGA-GIS;C:\Program Files
> C:\>saga_cmd grid_gridding "Inverse Distance Weighted" -SHAPES
> "C:/Users/me/Desktop/test/Scores/MA Full/Scores.shp" -FIELD "score" -TARGET
> 0 -WEIGHTING 0 -POWER 2 -BANDWIDTH 1 -RANGE 0 -RADIUS 100 -MODE 0 -POINTS 0
> -NPOINTS 10 -USER_XMIN 2135073.26163 -USER_XMAX 2442654.3611 -USER_YMIN
> 20206.1478731 -USER_YMAX 185532.363448 -USER_SIZE 0 -USER_GRID
> "C:\Users\me\AppData\Local\Temp\sextante\sagainversedistanceweighted2a326895f38d40229b126d04997aef7a.tif.sgrd"
> _____________________________________________
> library path: C:\Program Files (x86)\SAGA-GIS\modules
> library name: grid_gridding
> module name : Inverse Distance Weighted
> author : O.Conrad (c) 2003
> go...
> Load shapes: C:/Users/me/Desktop/test/Scores/MA Full/Scores.shp...
> ready
> okay
> Parameters
> Points: Scores
> Attribute: score
> Target Grid: user defined
> Distance Weighting: inverse distance to a power
> Inverse Distance Power: 2.000000
> Exponential and Gaussian Weighting Bandwidth: 1.000000
> Search Range: search radius (local)
> Search Radius: 100.000000
> Search Mode: all directions
> Number of Points: maximum number of points
> Maximum Number of Points: 10
> error: executing module [Inverse Distance Weighted]
> C:\>saga_cmd io_gdal 1 -GRIDS
> -FORMAT 1 -TYPE 0 -FILE
> "C:\Users\me\AppData\Local\Temp\sextante\sagainversedistanceweighted2a326895f38d40229b126d04997aef7a.tif"
> library name: io_gdal
> module name : GDAL: Export Raster
> author : O.Conrad (c) 2007
> go...
> Load grid:
> C:\Users\me\AppData\Local\Temp\sextante\sagainversedistanceweighted2a326895f38d40229b126d04997aef7a.tif.sgrd...
> failed
> error: Grid file could not be opened.
> error: input file
> [C:\Users\me\AppData\Local\Temp\sextante\sagainversedistanceweighted2a326895f38d40229b126d04997aef7a.tif.sgrd]
> error: empty input list [GRIDS]
> Usage: 1 -GRIDS <str> [-FILE <str>] [-FORMAT <str>] [-TYPE <str>]
> -GRIDS:<str> Grid(s)
> Grid list (input)
> -FILE:<str> File
> File path
> -FORMAT:<str> Format
> Choice
> Available Choices:
> [0] Virtual Raster
> [1] GeoTIFF
> [2] National Imagery Transmission Format
> [3] Erdas Imagine Images (.img)
> [4] ELAS
> [5] In Memory Raster
> [6] MS Windows Device Independent Bitmap
> [7] PCIDSK Database File
> [8] ILWIS Raster Map
> [9] SGI Image File Format 1.0
> [10] Leveller heightfield
> [11] Terragen heightfield
> [12] ERMapper .ers Labelled
> [13] Raster Matrix Format
> [14] Idrisi Raster A.1
> [15] Intergraph Raster
> [16] Golden Software Binary Grid (.grd)
> [17] Portable Pixmap Format (netpbm)
> [18] ENVI .hdr Labelled
> [19] ESRI .hdr Labelled
> [20] PCI .aux Labelled
> [21] Vexcel MFF Raster
> [22] Vexcel MFF2 (HKV) Raster
> [23] VTP .bt (Binary Terrain) 1.3 Format
> [24] Image Data and Analysis
> [25] NOAA Vertical Datum .GTX
> [26] NTv2 Datum Grid Shift
> [27] ARC Digitized Raster Graphics
> [28] SAGA GIS Binary Grid (.sdat)
> -TYPE:<str> Data Type
> Choice
> Available Choices:
> [0] match input data
> [1] 8 bit unsigned integer
> [2] 16 bit unsigned integer
> [3] 16 bit signed integer
> [4] 32 bit unsigned integer
> [5] 32 bit signed integer
> [6] 32 bit floating point
> [7] 64 bit floating point
> error: executing module [GDAL: Export Raster]
> C:\>exit
> SAGA execution commands
> io_gdal 1 -GRIDS
> On Sat, Apr 20, 2013 at 10:20 AM, Victor Olaya <volayaf at gmail.com> wrote:
>> Which version of SAGA are you using. It seems that the syntax is
>> different from the one used by SEXTANTE to call it. SEXTANTE is
>> adapted to SAGA 2.0.8
>> run "saga_cmd --help" on a console to see which version you are running
>> Cheers
>> Victor
>> > Hi everyone, I am trying to use some SAGA function (IDW) using QGIS 1.9
>> > 298f0c0 and the SEXTANTE plugin. SAGA 2.1 b3 64bit has already been
>> > installed and the OS is Windows 8.
>> > When I activate SAGA from the SEXTANTE options, I find in the error logs
>> > 2
>> > logs of:
>> > Could not load model watersheds.model
>> > ALGORITHM:ftools:export/addgeometrycolumns
>> > Next when I select SAGA's Inverse Distance Weighted function within
>> > Sextante, and use the default values for the parameters, I get an error
>> > popup saying:
>> > Could not load layer
>> > C:\Users\me\AppData\Local\Temp\sextante\sagainversedistanceweighted......tif.
>> > Check the SEXTANTE log to look for errors.
>> > In the SEXTANTE logs I find the following logs.
>> > Any ideas how we can get SEXTANTE to work? Thank you!!
>> > C:\>set SAGA=C:\Program Files\saga
>> > C:\>set SAGA_MLB=C:\Program Files\saga\modules
>> > C:\>PATH=PATH;C:\Program Files\saga;C:\Program Files\saga\modules
>> > -TARGET
>> > -POINTS 0
>> > "C:\Users\me\AppData\Local\Temp\sextante\sagainversedistanceweightedafef52b8ebe84495ac957c5155bd7f0a.tif.sgrd"
>> > Unknown option 'POWER'
>> > Usage: saga_cmd -SHAPES <str> [-FIELD <str>] [-TARGET <str>]
>> > [-SEARCH_RANGE
>> > <str>] [-SEARCH_RADIUS <str>] [-SEARCH_POINTS_ALL <str>]
>> > [-SEARCH_POINTS_MAX
>> > <num>] [-SEARCH_DIRECTION <str>] [-WEIGHTING <str>] [-WEIGHT_POWER
>> > <str>]
>> > [-WEIGHT_BANDWIDTH <str>] [-USER_XMIN <str>] [-USER_XMAX <str>]
>> > [-USER_YMIN
>> > <str>] [-USER_YMAX <str>] [-USER_SIZE <str>] [-USER_GRID <str>]
>> > [-GRID_GRID
>> > <str>]
>> > -SHAPES:<str> Points
>> > Shapes (input)
>> > -FIELD:<str> Attribute
>> > Table field
>> > -TARGET:<str> Target Grid
>> > Choice
>> > Available Choices:
>> > [0] user defined
>> > [1] grid
>> > -SEARCH_RANGE:<str> Search Range
>> > Choice
>> > Available Choices:
>> > [0] local
>> > [1] global
>> > -SEARCH_RADIUS:<str> Maximum Search Distance
>> > Floating point
>> > Minimum: 0.000000
>> > -SEARCH_POINTS_ALL:<str> Number of Points
>> > Choice
>> > Available Choices:
>> > [0] maximum number of nearest points
>> > [1] all points within search distance
>> > -SEARCH_POINTS_MAX:<num> Maximum Number of Points
>> > Integer
>> > Minimum: 1.000000
>> > -SEARCH_DIRECTION:<str> Search Direction
>> > Choice
>> > Available Choices:
>> > [0] all directions
>> > [1] quadrants
>> > -WEIGHTING:<str> Distance Weighting
>> > Choice
>> > Available Choices:
>> > [0] inverse distance to a power
>> > [1] linearly decreasing within search radius
>> > [2] exponential weighting scheme
>> > [3] gaussian weighting scheme
>> > -WEIGHT_POWER:<str> Power
>> > Floating point
>> > -WEIGHT_BANDWIDTH:<str> Bandwidth
>> > Floating point
>> > Minimum: 0.000000
>> > -USER_XMIN:<str> Left
>> > Floating point
>> > -USER_XMAX:<str> Right
>> > Floating point
>> > -USER_YMIN:<str> Bottom
>> > Floating point
>> > -USER_YMAX:<str> Top
>> > Floating point
>> > -USER_SIZE:<str> Cellsize
>> > Floating point
>> > Minimum: 0.000000
>> > -USER_GRID:<str> Grid
>> > Data Object (optional output)
>> > -GRID_GRID:<str> Grid
>> > Grid (output)
>> > "C:\Users\me\AppData\Local\Temp\sextante\sagainversedistanceweightedafef52b8ebe84495ac957c5155bd7f0a.tif"
>> > error: input file
>> > [C:\Users\me\AppData\Local\Temp\sextante\sagainversedistanceweightedafef52b8ebe84495ac957c5155bd7f0a.tif.sgrd]
>> > Usage: saga_cmd -GRIDS <str> [-FILE <str>] [-FORMAT <str>] [-TYPE <str>]
>> > [-OPTIONS <str>]
>> > Grid list (input)
>> > -FILE:<str> File
>> > File path
>> > Choice
>> > Available Choices:
>> > [0] ERDAS JPEG2000 (SDK 3.x)
>> > [1] Flexible Image Transport System
>> > [2] Network Common Data Format
>> > [3] Virtual Raster
>> > [4] GeoTIFF
>> > [5] National Imagery Transmission Format
>> > [6] Erdas Imagine Images (.img)
>> > [7] ELAS
>> > [8] In Memory Raster
>> > [9] MS Windows Device Independent Bitmap
>> > [10] PCIDSK Database File
>> > [11] ILWIS Raster Map
>> > [12] SGI Image File Format 1.0
>> > [13] Leveller heightfield
>> > [14] Terragen heightfield
>> > [15] USGS Astrogeology ISIS cube (Version 2)
>> > [16] ERMapper .ers Labelled
>> > [17] Raster Matrix Format
>> > [18] Idrisi Raster A.1
>> > [19] Intergraph Raster
>> > [20] Golden Software Binary Grid (.grd)
>> > [21] Portable Pixmap Format (netpbm)
>> > [22] ENVI .hdr Labelled
>> > [23] ESRI .hdr Labelled
>> > [24] PCI .aux Labelled
>> > [25] Vexcel MFF Raster
>> > [26] Vexcel MFF2 (HKV) Raster
>> > [27] VTP .bt (Binary Terrain) 1.3 Format
>> > [28] Erdas .LAN/.GIS
>> > [29] Image Data and Analysis
>> > [30] NOAA Vertical Datum .GTX
>> > [31] NTv2 Datum Grid Shift
>> > [32] ARC Digitized Raster Graphics
>> > [33] SAGA GIS Binary Grid (.sdat)
>> > Choice
>> > Available Choices:
>> > -OPTIONS:<str> Creation Options
>> > Text
>> > C:\>exit
>> > and
>> > -TARGET
>> > -POINTS 0
>> > io_gdal 1 -GRIDS
>> > _______________________________________________
>> > Qgis-user mailing list
>> > Qgis-user at lists.osgeo.org
>> > http://lists.osgeo.org/mailman/listinfo/qgis-user
