[Qgis-user] Error when using SAGA & SEXTANTE with QGIS 1.9
Nyx nyxynyx at gmail.com
Sat Apr 20 19:58:59 PDT 2013
Thank you, it works now. The raster produced via SEXTANTE and the one
produced directly in SAGA appears different, the one via SEXTANTE has many
tiny white spots. Will play around with it and see if I can get them to be
similar.
On Sat, Apr 20, 2013 at 12:48 PM, Victor Olaya <volayaf at gmail.com> wrote:
> Now it is working fine...but you are passing a cellsize of 0...that
> doesn't make too much sense :-) That's why SAGA cannot produce any
> output
> Having 0 as de default value doesn't make much sense, so I have
> changed it. Enter a better value there and it should work...
> Cheers
> Victor
> 2013/4/20 Nyx <nyxynyx at gmail.com>:
> > "saga_cmd --v" says its SAGA 2.1.0. I've changed to SAGA 2.0.8, "saga_cmd
> > -v" shows SAGA 2.0.8 and now I'm getting different errors when trying to
> do
> > IDW.
> > SAGA execution console output
> > C:\>set SAGA=C:\Program Files (x86)\SAGA-GIS
> > C:\>set SAGA_MLB=C:\Program Files (x86)\SAGA-GIS\modules
> > C:\>PATH=PATH;C:\Program Files (x86)\SAGA-GIS;C:\Program Files
> > C:\>saga_cmd grid_gridding "Inverse Distance Weighted" -SHAPES
> > "C:/Users/me/Desktop/test/Scores/MA Full/Scores.shp" -FIELD "score"
> -TARGET
> > 0 -WEIGHTING 0 -POWER 2 -BANDWIDTH 1 -RANGE 0 -RADIUS 100 -MODE 0
> -POINTS 0
> > -NPOINTS 10 -USER_XMIN 2135073.26163 -USER_XMAX 2442654.3611 -USER_YMIN
> > 20206.1478731 -USER_YMAX 185532.363448 -USER_SIZE 0 -USER_GRID
> "C:\Users\me\AppData\Local\Temp\sextante\sagainversedistanceweighted2a326895f38d40229b126d04997aef7a.tif.sgrd"
> > _____________________________________________
> > library path: C:\Program Files (x86)\SAGA-GIS\modules
> > library name: grid_gridding
> > module name : Inverse Distance Weighted
> > author      : O.Conrad (c) 2003
> > go...
> > Load shapes: C:/Users/me/Desktop/test/Scores/MA Full/Scores.shp...
> > ready
> > okay
> > Parameters
> > Points: Scores
> > Attribute: score
> > Target Grid: user defined
> > Distance Weighting: inverse distance to a power
> > Inverse Distance Power: 2.000000
> > Exponential and Gaussian Weighting Bandwidth: 1.000000
> > Search Range: search radius (local)
> > Search Radius: 100.000000
> > Search Mode: all directions
> > Number of Points: maximum number of points
> > Maximum Number of Points: 10
> > error: executing module [Inverse Distance Weighted]
> > C:\>saga_cmd io_gdal 1 -GRIDS
> > -FORMAT 1 -TYPE 0 -FILE
> "C:\Users\me\AppData\Local\Temp\sextante\sagainversedistanceweighted2a326895f38d40229b126d04997aef7a.tif"
> > library name: io_gdal
> > module name : GDAL: Export Raster
> > author      : O.Conrad (c) 2007
> > go...
> > Load grid:
> C:\Users\me\AppData\Local\Temp\sextante\sagainversedistanceweighted2a326895f38d40229b126d04997aef7a.tif.sgrd...
> > failed
> > error: Grid file could not be opened.
> > error: input file
> [C:\Users\me\AppData\Local\Temp\sextante\sagainversedistanceweighted2a326895f38d40229b126d04997aef7a.tif.sgrd]
> > error: empty input list [GRIDS]
> > Usage: 1 -GRIDS <str> [-FILE <str>] [-FORMAT <str>] [-TYPE <str>]
> > -GRIDS:<str> Grid(s)
> > Grid list (input)
> > -FILE:<str>   File
> > File path
> > -FORMAT:<str> Format
> > Choice
> > Available Choices:
> > [0] Virtual Raster
> > [1] GeoTIFF
> > [2] National Imagery Transmission Format
> > [3] Erdas Imagine Images (.img)
> > [4] ELAS
> > [5] In Memory Raster
> > [6] MS Windows Device Independent Bitmap
> > [7] PCIDSK Database File
> > [8] ILWIS Raster Map
> > [9] SGI Image File Format 1.0
> > [10] Leveller heightfield
> > [11] Terragen heightfield
> > [12] ERMapper .ers Labelled
> > [13] Raster Matrix Format
> > [14] Idrisi Raster A.1
> > [15] Intergraph Raster
> > [16] Golden Software Binary Grid (.grd)
> > [17] Portable Pixmap Format (netpbm)
> > [18] ENVI .hdr Labelled
> > [19] ESRI .hdr Labelled
> > [20] PCI .aux Labelled
> > [21] Vexcel MFF Raster
> > [22] Vexcel MFF2 (HKV) Raster
> > [23] VTP .bt (Binary Terrain) 1.3 Format
> > [24] Image Data and Analysis
> > [25] NOAA Vertical Datum .GTX
> > [26] NTv2 Datum Grid Shift
> > [27] ARC Digitized Raster Graphics
> > [28] SAGA GIS Binary Grid (.sdat)
> > -TYPE:<str>   Data Type
> > Choice
> > Available Choices:
> > [0] match input data
> > [1] 8 bit unsigned integer
> > [2] 16 bit unsigned integer
> > [3] 16 bit signed integer
> > [4] 32 bit unsigned integer
> > [5] 32 bit signed integer
> > [6] 32 bit floating point
> > [7] 64 bit floating point
> > error: executing module [GDAL: Export Raster]
> > C:\>exit
> > SAGA execution commands
> -TARGET
> -POINTS 0
> > io_gdal 1 -GRIDS
> > On Sat, Apr 20, 2013 at 10:20 AM, Victor Olaya <volayaf at gmail.com>
> wrote:
> >> Which version of SAGA are you using. It seems that the syntax is
> >> different from the one used by SEXTANTE to call it. SEXTANTE is
> >> adapted to SAGA 2.0.8
> >> run "saga_cmd --help" on a console to see which version you are running
> >> Cheers
> >> Victor
> >> > Hi everyone, I am trying to use some SAGA function (IDW) using QGIS
> 1.9
> >> > 298f0c0  and the SEXTANTE plugin. SAGA 2.1 b3 64bit has already been
> >> > installed and the OS is Windows 8.
> >> > When I activate SAGA from the SEXTANTE options, I find in the error
> logs
> >> > 2
> >> > logs of:
> >> > Could not load model watersheds.model
> >> > ALGORITHM:ftools:export/addgeometrycolumns
> >> > Next when I select SAGA's Inverse Distance Weighted function within
> >> > Sextante, and use the default values for the parameters, I get an
> error
> >> > popup saying:
> >> > Could not load layer
> C:\Users\me\AppData\Local\Temp\sextante\sagainversedistanceweighted......tif.
> >> > Check the SEXTANTE log to look for errors.
> >> > In the SEXTANTE logs I find the following logs.
> >> > Any ideas how we can get SEXTANTE to work? Thank you!!
> >> > C:\>set SAGA=C:\Program Files\saga
> >> > C:\>set SAGA_MLB=C:\Program Files\saga\modules
> >> > C:\>PATH=PATH;C:\Program Files\saga;C:\Program Files\saga\modules
> >> > -TARGET
> >> > -POINTS 0
> -USER_YMIN
> "C:\Users\me\AppData\Local\Temp\sextante\sagainversedistanceweightedafef52b8ebe84495ac957c5155bd7f0a.tif.sgrd"
> >> > Unknown option 'POWER'
> >> > Usage: saga_cmd -SHAPES <str> [-FIELD <str>] [-TARGET <str>]
> >> > [-SEARCH_RANGE
> >> > <str>] [-SEARCH_RADIUS <str>] [-SEARCH_POINTS_ALL <str>]
> >> > [-SEARCH_POINTS_MAX
> >> > <num>] [-SEARCH_DIRECTION <str>] [-WEIGHTING <str>] [-WEIGHT_POWER
> >> > <str>]
> >> > [-WEIGHT_BANDWIDTH <str>] [-USER_XMIN <str>] [-USER_XMAX <str>]
> >> > [-USER_YMIN
> >> > <str>] [-USER_YMAX <str>] [-USER_SIZE <str>] [-USER_GRID <str>]
> >> > [-GRID_GRID
> >> > <str>]
> >> > -SHAPES:<str>           Points
> >> > Shapes (input)
> >> > -FIELD:<str>             Attribute
> >> > Table field
> >> > -TARGET:<str>           Target Grid
> >> > Choice
> >> > Available Choices:
> >> > [0] user defined
> >> > [1] grid
> >> > -SEARCH_RANGE:<str>     Search Range
> >> > Choice
> >> > Available Choices:
> >> > [0] local
> >> > [1] global
> >> > -SEARCH_RADIUS:<str>     Maximum Search Distance
> >> > Floating point
> >> > Minimum: 0.000000
> >> > -SEARCH_POINTS_ALL:<str> Number of Points
> >> > Choice
> >> > Available Choices:
> >> > [0] maximum number of nearest points
> >> > [1] all points within search distance
> >> > -SEARCH_POINTS_MAX:<num> Maximum Number of Points
> >> > Integer
> >> > Minimum: 1.000000
> >> > -SEARCH_DIRECTION:<str> Search Direction
> >> > Choice
> >> > Available Choices:
> >> > [0] all directions
> >> > [1] quadrants
> >> > -WEIGHTING:<str>         Distance Weighting
> >> > Choice
> >> > Available Choices:
> >> > [0] inverse distance to a power
> >> > [1] linearly decreasing within search radius
> >> > [2] exponential weighting scheme
> >> > [3] gaussian weighting scheme
> >> > -WEIGHT_POWER:<str>     Power
> >> > Floating point
> >> > -WEIGHT_BANDWIDTH:<str> Bandwidth
> >> > Floating point
> >> > Minimum: 0.000000
> >> > -USER_XMIN:<str>         Left
> >> > Floating point
> >> > -USER_XMAX:<str>         Right
> >> > Floating point
> >> > -USER_YMIN:<str>         Bottom
> >> > Floating point
> >> > -USER_YMAX:<str>         Top
> >> > Floating point
> >> > -USER_SIZE:<str>         Cellsize
> >> > Floating point
> >> > Minimum: 0.000000
> >> > -USER_GRID:<str>         Grid
> >> > Data Object (optional output)
> >> > -GRID_GRID:<str>         Grid
> >> > Grid (output)
> "C:\Users\me\AppData\Local\Temp\sextante\sagainversedistanceweightedafef52b8ebe84495ac957c5155bd7f0a.tif"
> >> > error: input file
> [C:\Users\me\AppData\Local\Temp\sextante\sagainversedistanceweightedafef52b8ebe84495ac957c5155bd7f0a.tif.sgrd]
> >> > Usage: saga_cmd -GRIDS <str> [-FILE <str>] [-FORMAT <str>] [-TYPE
> <str>]
> >> > [-OPTIONS <str>]
> >> > Grid list (input)
> >> > -FILE:<str>   File
> >> > File path
> >> > Choice
> >> > Available Choices:
> >> > [0] ERDAS JPEG2000 (SDK 3.x)
> >> > [1] Flexible Image Transport System
> >> > [2] Network Common Data Format
> >> > [3] Virtual Raster
> >> > [4] GeoTIFF
> >> > [5] National Imagery Transmission Format
> >> > [6] Erdas Imagine Images (.img)
> >> > [7] ELAS
> >> > [8] In Memory Raster
> >> > [9] MS Windows Device Independent Bitmap
> >> > [10] PCIDSK Database File
> >> > [11] ILWIS Raster Map
> >> > [12] SGI Image File Format 1.0
> >> > [13] Leveller heightfield
> >> > [14] Terragen heightfield
> >> > [15] USGS Astrogeology ISIS cube (Version 2)
> >> > [16] ERMapper .ers Labelled
> >> > [17] Raster Matrix Format
> >> > [18] Idrisi Raster A.1
> >> > [19] Intergraph Raster
> >> > [20] Golden Software Binary Grid (.grd)
> >> > [21] Portable Pixmap Format (netpbm)
> >> > [22] ENVI .hdr Labelled
> >> > [23] ESRI .hdr Labelled
> >> > [24] PCI .aux Labelled
> >> > [25] Vexcel MFF Raster
> >> > [26] Vexcel MFF2 (HKV) Raster
> >> > [27] VTP .bt (Binary Terrain) 1.3 Format
> >> > [28] Erdas .LAN/.GIS
> >> > [29] Image Data and Analysis
> >> > [30] NOAA Vertical Datum .GTX
> >> > [31] NTv2 Datum Grid Shift
> >> > [32] ARC Digitized Raster Graphics
> >> > [33] SAGA GIS Binary Grid (.sdat)
> >> > Choice
> >> > Available Choices:
> >> > -OPTIONS:<str> Creation Options
> >> > Text
> >> > C:\>exit
> >> > and
> >> > -TARGET
> >> > -POINTS 0
> -USER_YMIN
> >> > io_gdal 1 -GRIDS
> >> > _______________________________________________
> >> > Qgis-user mailing list
> >> > Qgis-user at lists.osgeo.org
> >> > http://lists.osgeo.org/mailman/listinfo/qgis-user
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20130420/aa06912e/attachment.html>
