[Qgis-user] Sextante Modeler Error “global name os is not defined”
Victor Olaya
volayaf at gmail.com
Sun Apr 21 11:04:18 PDT 2013
Jonas
The latest version is the one that comes with QGIS 1.9, not the latest
stable. Make sure that you have unistalled your previous SEXTANTE, to
avoid conflict between both of them. It seems that it is using the
older version...
Regards
VIctor
2013/4/21 Jonas Sjögren <jonas.sjo at gmail.com>:
> Hi,
> I´m using Sextante Modeler and have made a model that reclassifies raster
> values and produces an area. When running the model I get an error, "global
> name 'os' is not defined" (see screenshot attached). Exactly the same error
> is described in QGIS Issue Tracking #7587 (http://hub.qgis.org/issues/7587)
> where the solution is to use QGIS 1.9 and the lastest Sextante version. So I
> installed 1.9.0 Master QGIS and use Sextante 1.0.9. However, I still face
> the same error. Does anyone have a hint?
> /Jonas
> Qgis-user mailing list
