[Qgis-user] MrSID raster and QGIS in linux
BigBaka hunt.glenn at gmail.com
Tue Dec 3 09:07:30 PST 2013
Re configured, make, and make installed gdal. Moved onto the postgis
Downloaded package but when in tried to configure i got an error
checking for pg_config... no
configure: error: could not find pg_config within the current path. You
may need to try re-running configure with a --with-pgconfig parameter.
make: *** [GNUmakefile] Error 1
ideas?
On 03/12/13 23:26, Eric Goddard [via OSGeo.org] wrote:
> I would recompile gdal. Switch to the gdal source directory and run
> 'make clean', and then re run the ./configure, make, and make install
> lines.
> On Tue, Dec 3, 2013 at 10:21 AM, BigBaka <[hidden email]
> </user/SendEmail.jtp?type=node&node=5092441&i=0>> wrote:
> > After posting that I went into synaptic and installed geotiff 1.4.
> Following
> > that it seems it worked.
> > Values for GEOTIFF_INCLUDE_DIR and GEOTIFF_LIBRARY
> > are usr/include/geotiff and usr/lib/libgeotiff.so respectively now.
> > I did manage to get the gdal compiled without geotiff, but I'm not sure
> > there may have been some errors that I just overlooked. Would you
> recommend
> > starting from the beginning again, or just keep going as is?
> > Regards,
> > BB
> > View this message in context:
> http://osgeo-org.1560.x6.nabble.com/MrSID-raster-and-QGIS-in-linux-tp5090885p5092439.html
> > Sent from the Quantum GIS - User mailing list archive at Nabble.com.
> > Qgis-user mailing list
> > [hidden email] </user/SendEmail.jtp?type=node&node=5092441&i=1>
> > http://lists.osgeo.org/mailman/listinfo/qgis-user
> [hidden email] </user/SendEmail.jtp?type=node&node=5092441&i=2>
> If you reply to this email, your message will be added to the
> discussion below:
> http://osgeo-org.1560.x6.nabble.com/MrSID-raster-and-QGIS-in-linux-tp5090885p5092441.html
> To unsubscribe from MrSID raster and QGIS in linux, click here
> <http://osgeo-org.1560.x6.nabble.com/template/NamlServlet.jtp?macro=unsubscribe_by_code&node=5090885&code=aHVudC5nbGVubkBnbWFpbC5jb218NTA5MDg4NXwtMjA4MDk5NDE3MA==>.
> NAML
> <http://osgeo-org.1560.x6.nabble.com/template/NamlServlet.jtp?macro=macro_viewer&id=instant_html%21nabble%3Aemail.naml&base=nabble.naml.namespaces.BasicNamespace-nabble.view.web.template.NabbleNamespace-nabble.view.web.template.NodeNamespace&breadcrumbs=notify_subscribers%21nabble%3Aemail.naml-instant_emails%21nabble%3Aemail.naml-send_instant_email%21nabble%3Aemail.naml>
View this message in context: http://osgeo-org.1560.x6.nabble.com/MrSID-raster-and-QGIS-in-linux-tp5090885p5092460.html
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20131203/484a2f0f/attachment.html>
