[Qgis-user] MrSID raster and QGIS in linux
Eric Goddard
egoddard1010 at gmail.com
Tue Dec 3 09:20:01 PST 2013
The packages I use for postgres on Ubuntu 13.04 are:
postgresql-server-dev-9.1 postgresql-client postgresql-9.1
postgresql-contrib-9.1. I don't know if Ubuntu 12.04 has postgres 9.1;
it may still be on 9. Try finding the equivalent packages with
synaptic, or simply don't compile postgis if you never use it.
On Tue, Dec 3, 2013 at 11:07 AM, BigBaka <hunt.glenn at gmail.com> wrote:
> Re configured, make, and make installed gdal. Moved onto the postgis
> Downloaded package but when in tried to configure i got an error
> checking for pg_config... no
> configure: error: could not find pg_config within the current path. You may
> need to try re-running configure with a --with-pgconfig parameter.
> make: *** [GNUmakefile] Error 1
> ideas?
> On 03/12/13 23:26, Eric Goddard [via OSGeo.org] wrote:
> I would recompile gdal. Switch to the gdal source directory and run
> 'make clean', and then re run the ./configure, make, and make install
> lines.
> On Tue, Dec 3, 2013 at 10:21 AM, BigBaka <[hidden email]> wrote:
>> After posting that I went into synaptic and installed geotiff 1.4.
>> Following
>> that it seems it worked.
>> Values for GEOTIFF_INCLUDE_DIR and GEOTIFF_LIBRARY
>> are usr/include/geotiff and usr/lib/libgeotiff.so respectively now.
>> I did manage to get the gdal compiled without geotiff, but I'm not sure
>> there may have been some errors that I just overlooked. Would you
>> recommend
>> starting from the beginning again, or just keep going as is?
>> Regards,
>> BB
>> View this message in context:
>> http://osgeo-org.1560.x6.nabble.com/MrSID-raster-and-QGIS-in-linux-tp5090885p5092439.html
>> Sent from the Quantum GIS - User mailing list archive at Nabble.com.
>> Qgis-user mailing list
>> [hidden email]
>> http://lists.osgeo.org/mailman/listinfo/qgis-user
> [hidden email]
> If you reply to this email, your message will be added to the discussion
> below:
> http://osgeo-org.1560.x6.nabble.com/MrSID-raster-and-QGIS-in-linux-tp5090885p5092441.html
> To unsubscribe from MrSID raster and QGIS in linux, click here.
> NAML
> View this message in context: Re: MrSID raster and QGIS in linux
