[Qgis-user] MrSID raster and QGIS in linux
Glenn Hunt hunt.glenn at gmail.com
Tue Dec 3 23:42:01 PST 2013
Hi Eric,
I decided not to compile postgis but do I then need to change the
configure line for compiling grass 64? I just tried to compile now using
the full text in your document and got an error right at the beginning.
checing for lex... no
configure: error: *** Unable to locate lex.
On 04/12/13 00:20, Eric Goddard wrote:
> The packages I use for postgres on Ubuntu 13.04 are:
> postgresql-server-dev-9.1 postgresql-client postgresql-9.1
> postgresql-contrib-9.1. I don't know if Ubuntu 12.04 has postgres 9.1;
> it may still be on 9. Try finding the equivalent packages with
> synaptic, or simply don't compile postgis if you never use it.
> On Tue, Dec 3, 2013 at 11:07 AM, BigBaka <hunt.glenn at gmail.com> wrote:
>> Re configured, make, and make installed gdal. Moved onto the postgis
>> Downloaded package but when in tried to configure i got an error
>> checking for pg_config... no
>> configure: error: could not find pg_config within the current path. You may
>> need to try re-running configure with a --with-pgconfig parameter.
>> make: *** [GNUmakefile] Error 1
>> ideas?
>> On 03/12/13 23:26, Eric Goddard [via OSGeo.org] wrote:
>> I would recompile gdal. Switch to the gdal source directory and run
>> 'make clean', and then re run the ./configure, make, and make install
>> lines.
>> On Tue, Dec 3, 2013 at 10:21 AM, BigBaka <[hidden email]> wrote:
>>> After posting that I went into synaptic and installed geotiff 1.4.
>>> Following
>>> that it seems it worked.
>>> Values for GEOTIFF_INCLUDE_DIR and GEOTIFF_LIBRARY
>>> are usr/include/geotiff and usr/lib/libgeotiff.so respectively now.
>>> I did manage to get the gdal compiled without geotiff, but I'm not sure
>>> there may have been some errors that I just overlooked. Would you
>>> recommend
>>> starting from the beginning again, or just keep going as is?
>>> Regards,
>>> BB
>>> View this message in context:
>>> http://osgeo-org.1560.x6.nabble.com/MrSID-raster-and-QGIS-in-linux-tp5090885p5092439.html
>>> Sent from the Quantum GIS - User mailing list archive at Nabble.com.
>>> Qgis-user mailing list
>>> [hidden email]
>>> http://lists.osgeo.org/mailman/listinfo/qgis-user
>> [hidden email]
>> If you reply to this email, your message will be added to the discussion
>> below:
>> http://osgeo-org.1560.x6.nabble.com/MrSID-raster-and-QGIS-in-linux-tp5090885p5092441.html
>> To unsubscribe from MrSID raster and QGIS in linux, click here.
>> NAML
>> View this message in context: Re: MrSID raster and QGIS in linux
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20131204/addae06d/attachment.html>
