[Qgis-user] Open and read shapefile plugin in QGIS dufour
Etienne Tourigny
etourigny.dev at gmail.com
Tue Dec 10 09:34:35 PST 2013
Out of curiosity, why do you use pyshp when shapefiles are already
supported by qgis?
On Tue, Dec 10, 2013 at 2:51 PM, Suryo Miles <suryomiles666 at gmail.com>wrote:
> I try to make plugin to read shapefile with plugin builder in QGIS and i
> try to import pyshp in plugin to read shapefiles but i got this error
> message
> Traceback (most recent call last):
> File "C:\Users\Mr.Pakde/.qgis2/python/plugins\shpread\shpreaddialog.py",
> line 42, in baca
> shapefile.Reader("shapefiles/blockgroups")
> File "C:\Users\Mr.Pakde/.qgis2/python/plugins\shpread\shapefile.py",
> line 220, in __init__
> self.load(args[0])
> line 253, in load
> raise ShapefileException("Unable to open %s.shp" % shapeName)
> ShapefileException: Unable to open shapefiles/blockgroups.shp
> Python version:
> 2.7.4 (default, Apr 6 2013, 19:54:46) [MSC v.1500 32 bit (Intel)]
> ------and this is code i use ( i put it in dialog.py)-------
> # insert every signal connection here!
> cariButton = self.ui.btnShp
> QtCore.QObject.connect(cariButton,
> QtCore.SIGNAL('clicked()'),self.baca)
> def baca(self):
> sf = QtGui.QFileDialog.getOpenFileName(self, 'Open File', '*.shp')
> shapes = sf.shapes()
> # Read the bounding box from the 4th shape
> shapes[3].bbox
> [-122.485792, 37.786931000000003, -122.446285, 37.811019000000002]
> # Read the 8th point in the 4th shape
> shapes[3].points[7]
> [-122.471063, 37.787402999999998]
> #panggil isi data
> self.isiDataFile(sf)
> def isiDataFile(self, nmfile):
> #buka dengan open mode baca
> teksFile = open(nmfile, 'r').read()
> self.ui.textShp.setText(teksFile)
> can someone help me?
> Qgis-user mailing list
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20131210/395d8f8f/attachment.html>
